Question about Acer Computers & Internet
Power problem my laptop open when he want once open ance does not open i want to know the mainboard name for this model .
  • 797 Answers
To open up some of these laptops, can be a problem to solve. Go to the home page of the computer.
Posted on Sep 02, 2008
Hp laptop's audio driver for intel 1.86GHz
Hello first of all you can not find anything at the intel site:
http://downloadcenter.intel.com/
Because HP has the support for the mainboard
You can seach for audio drivers here at HP:
http://www8.hp.com/us/en/support-drivers.html
Enter the model number manualy or use the automatic find function.
The model number is placed under the laptop on a sticker
it should be fairly easy to find.
Remember also to select your windows system.
Good luck
Nov 17, 2012 | Intel Motherboard
Lenovo g410 not charging
This is going to be one of three things either your power supply is not giving out enough voltage to charge the battery, have you tried another psu?
If its not the psu then it could be the dc socket being loose on the mainboard or the fuse which controls the charging section has blown which means you need a replacement mainboard. Usually its either the charger or dc socket
Mar 23, 2012 | Computers & Internet
The pin that u put the charger in has went back in the laptop. how to open it to get to it to fix it.
The power socket on a laptop is usually soldered directly to the mainboard. Sometimes the socket is on a seperate smaller daughterboard or on a cable that connects to the mainboard, but usually this is not the case. Opening the laptop to perform this repair can be very trick and time consuming. I would certainly not recommend an amateur attempting this repair as usually the entire board needs to be removed, the socket de-soldered and a new socket soldered in place. Not for the faint hearted! If you wish to provide laptop model details I may be able to provide the screw locations etc and disassembly guide.
May 29, 2011 | Computers & Internet
I disconnected my WB drive by accident, and now i cant acces it from any of my computers... the blue light is on and flicking but it wont open. how can i fix this. gabriel felix mexico
Since you said you are unable to access it from any of your computers might external HD might have crashed. The only advice I can give you in this case is to remove any power to the device, then plug in the USB first then the power, see if the computer detects it. If not reboot the computer and test
hope this helps
Mar 08, 2011 | Western Digital My Book Essential 1TB...
How could we know the right model to download the right audio driver in your PC
You need the model number of you computer mainboard, if you are using onboard audio and if you are using a sound card you would need the model number of that card. The model number of the mainboard can be found, either between the PCI, PCI-Express, AGP slots or near the RAM slots.
So it's the name of the manufacturer of your computer mainboard, eg: Asus, MSI, Gigabyte, Abit, Foxcon etc... and the number that follows.
Then go to the manufacturers website and under the support heading, find your mainboard audio drivers.
damnor01
Dec 19, 2010 | Computers & Internet
I need to know the cpu socket on my msi
Type the name and model number of your mainboard into google, remember to include the VER number. Your model number of your mainboard can usually be found between the PCI, VGA, AGP slots. Also include Specifications in your search. Alternatively post your Model number for your mainboard down below and I will find out the CPU socket for you.
All the best, thumbs up!!!
damnor01
Oct 20, 2010 | MSI Computers & Internet
How can i get suitable sound driver for my motherboard if the driver get uninstalled from my system????????
If your know the model or name for the mainboard ie OEM it make thing easier to search for the needed drivers from the Manufacturer website. ie (Assumming your Audio device is intergrated with the mainboard)
or
You can open up your PC to locate the Audio Chipset ID on the mainboard and search for a generic compatible audio driver.
Hope it helps.
Aug 08, 2010 | Microsoft Computers & Internet
V25 laptop will not turn on from battery power
The problem associated with Laptop not being able to power from the Battery, even if the Battery is new, can be attribute to the mainboard charging Electronic. The charging electronic in Mainboard is perharps defect. If your laptop still have warranty, this is the best time to change the mainboard.If not, seek for a qualified technician to check the PC, run the system, make Bios Update, and have the mainboard checked.
Nov 08, 2008 | Samsung V25 XVC 2800 Notebook
Power problem
There is no exact name for this main board. All you need to know when replacing the main board is that the Insp 1100 and The Insp 1150 main board will fit. If you are going to change out the board, I suggest going with the board from an Inspiron 1150, it is an upgrade for the Insp 1100, and has built in wireless.
Sep 02, 2008 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
