Question about Epson PhotoPC 650 Digital Camera
Poor image quality
My pictures display poor image quality on the screen or when you print them out.
    Master:
  • 542 Answers
HotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Posted on Sep 13, 2005
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Poor picture quality
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Poor print quality
Can you add a picture of poor quality?
Apr 04, 2014 | Lexmark LEXE260X22G - E260X22G...
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
Jul 15, 2009 | E-Machines M6811 Notebook
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Poor display quality (wallpapers, photos etc) of samsung g600
u should save images as .bmp and than transfer them to your g600, or save them as .jpeg but resolution should be 240x320 or less for good previewing!
Pictures in my photos just zoom in and out and quality is way better!
Or save some of them in mms save and then you can view it in full screen in that sms.
hope it helps a bit..
Nov 21, 2008 | Samsung SGH-G600 Cellular Phone
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Open Questions:
I just bought an Epson 650 digital camera. I know, it's not new and fancy, but it's all I could afford right now. I bought this one (from ebay) mainly because my daughter has the same one- she bought several years ago, for around$350. I've noticed what big, clear, detailed pictures it takes (she sends to me). She resizes the pictures smaller, but the resolution on hers is 144. she uses one of the "better" settings, not the standard and not the BEST. What I've noticed with mine is, the resolution is 75 and the pictures don' tseem as clear and detailed. This might be partially because the scenery ones I've taken are of SNOW. I've tried using all the settings, even the very best, which only takes 3 pictures. The resolution is still 75. The picture size is big, 15"X 11". They are JPEG. I tried using he HotShots software that came with it, and now use Paint Shop Pro 7, with AQUIRE (Twain). I tried using the memory card in the USB cable that came with it, but it seemed to be clashing with my CD burner, which is in the other USB port. It's just as easy to use the camera and serial port and PSP. My daughter doesn't know much about it, she just takes the pictures and then takes them off. Hers have always been 144 resolution. I'm not saying the pictures on mine aren't good, and they're better than the Kodak DC 3200 I've had for over a year. Just that they don't seem as good as my daughter's, and it's the exact same camera. Could it be the memory (flashcard) that sets the resolution of the pictures? I have the original 8 MB one that came with the camera and my daughter once bought a bigger one. I know I can change the resolution in PSP to something higher if I want. I've been trying to find out what decides what the resolution of the pictures (when taken off the camera) might be? I can't find anything in the directions book about the settings for this. Just the "standard, better, best and extra fine". But, they all take pictures with 75 resolution.
Feb 27, 2017 | Epson PhotoPC 650 Digital Camera
Epson PhotoPC 650 Digital Camera Logo
176 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
