Question about HP Color LaserJet 2600n Printer
Won't power up
I have bought a secondhand 2600n laserjet but it will not power up. Yes the both the plug and printer are turned on. My husband could repair it if he knows what the problem is and where to get the part.
  • 300 Answers
There is an internal fuse on the low voltage power supply, to get to it you need to remove the top covers and to do that you need to remove both the side covers. Hope this helps
Posted on Sep 02, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
GOOD AFTERNOON, AFTER THE EXCHANGE'S BLACK AND MAGENTA TONER PRINTER HP COLOR LASERJET 2600N 55.1 HAS THE ERROR AND EVEN BACK TO THE ORIGINAL CARTRIDGES and update the firmware the error persists.
55.1 Error DC controller error.
The device has experienced an internal hardware error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it.
Plug the device directly into the wall socket. Use the power switch to turn the device on.
Check the engine (DCC) firmware version.
Update if needed. Replace the DCC if a firmware upgrade does not resolve the issue.
Jul 13, 2011 | HP Color LaserJet 2600n Printer
Hp color laser 2600n error 51.23
51.23 Error-yellow scanner error
Try this:
initialize.
it. Plug the device directly into the wall
device on.
Laser scanners are not replaceable.
Replace the engine.
Jun 28, 2011 | HP Color LaserJet 2600n Printer
Hp laserjet 2600n printer has a 51.22 error even after removing the toners
hardware error.
51.22 Error-magenta scanner error
try this:
initialize.
device on.
Replace the engine.
Oct 30, 2010 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
No black printing out in my 2600n printer
Try taking the black toner cartridge out, hold it by its ends and rock it back and forth several times. Also gently tap on the catridge a few times too. This will dislodge and redistribute the toner which is still inside.
Nov 16, 2008 | HP Color LaserJet 2600n Printer
Cleaning
Yes , you can manually clean the printer usually you can use a lint free cloth to do so. I don't recommend taking canned air and blowing it out. As far as the ghosting goes yes you seem to have a fuser problem and best case is to have service done to replace the fuser!! Hope I have helped!!!
Nov 13, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
