Question about Samsung Computers & Internet
Dead HM120JC Samsung hard drive (applied 12 vdc)
My laptop hdd was having problems so was going to take data off it then reload windows.
-I installed the harddrive into my desktop PC using a IDE conversion adapter
- I accidenataly applied 12V to it rather than 5V so burned it out.
- I am going to replace the burned out component on the cct board of hdd because I need that data.
- does anybody know what the usual component on the cct board of the hdd burns out and where it might be located?
Thanks
  • aftershock Sep 16, 2008
    Thanks for the assistance
I have a hm120j, unfortunatly i dont have a photo of the platters,but the drives are horrible if moved or rotated whilst being written too at full speed they will scratch the platters and instantly destroy the drive which happend to mine in my laptop, as it was lifted up from a desk during a transfer,unacceptable, altho what im saying may not sound relivant, my reccomendation is forget the drive even if you do fix it its still a horrific drive, if the data on it is very important, you can take it to a hdd/data expert who can extract the platters and read them. do not open the drive yourself as you will instantly destroy it, hopefully this helps, excuse the typos
Posted on Sep 15, 2008
    Sergeant:
  • 300 Answers
Components normaly burn out due to power surge or over volt situation or over current situation.
don't go against me , I'm the engineer.
remember if it's not hebrew , it's a lie :-> shalom lhime !
Posted on Sep 09, 2008
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Cannot detect hard drive when I turned on Dell
It's not dead or infected!! When the laptop turns on, press F2 this gets you into bios. Go to "Boot Sequence" If "Hard Drive" is listed there, then your hdd's dead! if not, go down until you highlight your hard drive. Mine says: HDD:C press space. it should now have a number next to it. Press "Space" on all the other numbers until your hard drive says: 1.HDD:C or whatever your harddrive says! press "Esc" and press save. now your hard drive should work. This might work for your laptop if your bios is "A011"
Nov 17, 2009 | Dell Inspiron 1525 Notebook
My samsung hm120jc hhd is not working.though t was working first.my com says usb drive not recocnessed. please help me . suggest me driver download
There are a few reasons this would happen, The options are a bad USB cable, a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians test it with a new USB cable, if it works buy the new cable. If that also fails to work have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Nov 03, 2009 | Samsung SpinPoint M60 HM120JC 120 GB Hard...
Hello from New Zealand, Have to organise price and info in the morning. Do you have any ideas how to reboot a Toshiba satellite P20 It says boot from original start disc, but we do not won?t to lose all...
You can boot from original Windows disk but make sure you choose to repair installation. This will replace all the windows files but will not touch any of your personal data, programs or drivers installed. After youve done this repair install you should be able to start windows and get yourself an external hard drive and back up all data. Maybe then do a complete format and reload operating system to get your laptop running like brand new again. I dont know why your IT specialist has never tried this? Hope this all works fine for you ....... cheers from Scott
Nov 01, 2009 | Toshiba Satellite P25-S609 Notebook
My external Samsung HM120JC 120 GB Hard Drive not responding
Not sure what could be the problem.
There are many issues here.
- Did this drive worked before?
- If it did, was this your boot drive?
- USB cable and connector problems
- How is this connected to the drive?
- Is it in a package that came with the drive complete, or you had to install it?
My two cents... Samsung and other Japanese drives are not that reliable and if it's new, return it and get a Seagate drive. They have five year warranty and much better drives.
Apr 08, 2009 | Computers & Internet
Hard Drive
what do you mean with "crashed" ?
if your harddrive is dead, you need to replace your hdd.
if your OS is crashed, try to go to safe mode and backup your data, and reload the OS.
if you have software to diagnostic your hdd and rams it would be good to diagnostic that. it might found what it cause your hdd crashed
Aug 09, 2008 | Acer Aspire 3680 Laptop
Error to Detect, hardisk must be formatted
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Mar 12, 2008 | Computers & Internet
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
392 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
