Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Display out Model PFS 22 M15A BB The display that shows temperatures and allows you to make temperature adjustments is blanked out. Also no display for turbo cool or change water filter
  • john039 Sep 03, 2008
    I opened the top two doors, the only elctrical I found were the two push buttons at the top hinges that turned the lights on and off. Are they what you mean? Should I be looking in the bottom freezer?
  • labahn Nov 17, 2008
    My GE Stainless French Door refrigerator (2005 model) has an internal temp display/control in the refrig compartment. It is dark - no LED lights. I unplug the unit to "reboot" the appliance computer, and the display comes back for a while....but 10 minutes later the display is dark again. The refrigerator seems to be running colder than set.....vegetables are freezing.
  • 74 Answers
Does the display not light up when you press a button ?? Check the electrical connector at the bottom of the door as it may have corroded or become disconnected.
Posted on Sep 02, 2008
  • Graham Davies Sep 08, 2008
    no , at the very bottom of the frz door there is an electrical cable and water pipe that comes up through the bottom hinge pin.
The adjust temp numbers on my GE side by side fridge went out
Try this 1. First make sure the machine is turned on and running, both fans and compressor should be running. 2.Then unplug the machine for minimum 2 minutes. 3.Restore power to the refrigerator and wait 2 minutes. 4.Control diagnostics test using the display does not use error codes to identify problems. Instead, the temperature display allows access to components or systems to be checked if a problem is detected. 5.The temperature display must be in an active mode before entering the self-diagnosis test. 6.If the display is blank, press any temperature button once, then release it. The display will show actual temperatures.7. Enter the diagnostic mode by pressing both the freezer temperature (COLDER and WARMER) pads and the refrigerator temperature (COLDER and WARMER) pads simultaneously. All four pads must be held for approximately 3 seconds. Blinking "00"s in both the freezer and refrigerator sections of the display indicates the refrigerator has entered the test mode. 8.Remove fingers within 5 seconds and press any pad to lock-in the test mode. The blinking "00"s will change over to solid (non-blinking) "0"s when the test mode is locked in Failure to lock-in the test mode within 30 seconds will time out the test and return the refrigerator to the normal cooling mode. 9.Use the temperature colder or warmer pads to enter 1 in the freezer display and 5 in the fresh food display and press any button. This will cause a system reset.10. Wait 30 seconds and try to adjust the temperatures again. If the problem still exists, remove the cover over the motherboard behind the machine.11. Measure the voltage between J4-2 and J4-3 You should have 12 VDC (do not disconnect the J4 connector).12.If the voltage is correct confirm the voltage on the display board J3-2 and J3-3 I 13.if the voltage is correct, replace the display board. If not replace the motherboard.
Aug 24, 2017 | GE Refrigerators
What does S6 mean on digital temp display. My display is completely blank but if I touch any button s6 shows on display
I know of no camera which has a temperature display - what make and model of camera is displaying this problem ?
Feb 15, 2017 | Cameras
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Dec 02, 2014 | Hotpoint RGB745 Gas Kitchen Range
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
Oven temperature is inaccurate and takes a long time to heat to proper temp. I have replaced thermostat with no improvement.
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 12, 2011 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
219 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
