Question about Philips 46PP9302 46" Rear Projection Television
Phillips hd projection tv/ model 60pp9363h/17
My picture is warping and all words look to be 3d. The tv is september 2003. I have had it since January 2004.
Help!!!
Nina
  • Philips Master
  • 8,617 Answers
Thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 01, 2008
My philips 60pp9363h/17 is really dark and has a really red tint to it....we have tried adjusting the color of the t.v. with the remote but it dosent help.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Philips 60PP9363 60" Rear Projection...
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
How do you get to the convergance menu on phillips 60pp9363h/17 tv
Here are two tips from www.TvRepairKits.com
"You must have the original remote. If so you can access the convergence screen by hitting the menu key"
Jun 04, 2009 | Philips 46PP9302 46" Rear Projection...
In need of better picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 23, 2009 | Philips 60PP9363 60" Rear Projection...
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Phillips 60PP9363H/17 Picure warped and collor drifting
You have a convergence chip problem. You need to get a kit from www.TvRepairKits.com.
Note: The longer you run your set with a convergence problem the more problems you will have. Turn it off and get it fixed.
Nov 14, 2008 | Philips 60PP9363 60" Rear Projection...
Philips 60pp9363h/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
147 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
