Question about Dryers
Removing top from Whirlpool Gold Ultimate Care Model GEQ8858KQ0 Dryer
I have a new type Whirlpool Dryer that I am trying to remove top so that I can get to the screws holding a fin or vane in the Dryer drum. A coin is underneath the vane and I need to take it out. My older type of Whirlpool dryer hinged on the back when two clips at the top front edge was pushed. This dryer does not appear to have this hinge feature. Sugestions?
rayeason@ix.netcom.com
  • raisinet Sep 01, 2008
    Here is the answer to my own question and for anyone else who may have a similar noise problem with coins , metal objects, etc getting under the vanes or fins in the dryer drum. DISCONNECT OR UNPLUG DRYER-Remove 4 screws from the back edge of the control panel on the back of the dryer. Then lift up on the backside of the cover that also has the control unit attached to it. Slide the top cover towards the front of the dryer and then lift up on front and lay the entire cover and control panel towards the back of the dryer. A wall works great to hold this out of your way. The control panel remains on the cover and the drum will stay intact. Rotate the drum to locate which fin or vane the object is located. Move this vane to top and then remove three screws that is holding the vane. These are course threaded screws that screw into the plastic vanes. a nu6t driver was required. After removing the vane I found a quarter, and a few lint balls, There are only three vanes in the drum, so take about 10 more minutes and remove all three vanes to clean out the lint.To reinstall cover slide the cover back onto the two clips(one on each side) push towards back, checking to make sure front is held down by the clips, then replace the 4 screws on backside of dryer. If the lady of the house is around, it would now be a good time to clean out from behind and under the dryer to get up the rest of the dust, lint, and whatever remains or was lost.
  • Anonymous Dec 25, 2008
    How do you remove the front toe panel?
Posted on Sep 02, 2008
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpoole gold top loader stop working
Try pushing down on lid switch. common problem for these models.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I take off Whirlpool Washer cabinet to get to the pump
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
click on your model number. The new window will give diagrams in the left-hand side.
Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do brass (gold) clips go back into the slots when trying to put Whirlpool Ultimate Care II back panel back on after repairs are done?
they can only go in one way it's a matter of figuring it out. Believe me I've taken more time trying to figure this out when I did not pay attention as to how they were before removing.
Apr 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
May 24, 2008 | Dryers
Whirlpool ultimate care II gold electric dryer
the top and the front has to come off
Feb 04, 2008 | LG DLG2524 Gas Dryer
Dryers Logo
927 people viewed this question
Top Dryers Experts
