Question about Garmin Rino 120 2-Way Radio
Turn it on - black screen
I'm pretty sure this is a contrast problem, but I can't see the screen to adjust it
Dropped the rino 120 and the led is blank but radio works
Posted on Sep 20, 2008
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
When I turned it it has a black screen, the entire screen is black and none of the keys do anything. I replaced the batteries.
I think your keys still work, but you need to adjust your contrast. To adjust the contrast by lightening the screen, press and release the "2nd" button and hold the down arrow. Reply back if this doesn't work. Hope this solution helps!
Jan 15, 2011 | Texas Instruments TI-83 Plus Calculator
I changed batteries and now the screen is black. How do I fix it?
Hello, it sounds like your contrast needs adjusting. Turn your calculator on; press the "2nd" key and down. The contrast should adjust.
Happy calculating
Jul 31, 2010 | Texas Instruments TI-83 Plus Calculator
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen on my TI-86 calculator is black when I turn it on. What do I do?
You can adjust the contrast on the screen of your TI86 by following the procedure below.
Adjusting the Contrast
1 Press and release the yellow [2nd] key.
2 Press and hold UpArrow or DownArrow (above or below the half-shaded circle).
¨ To darken the screen contrast, press and hold UpArrow.
¨ To lighten the screen contrast, press and hold DownArrow.
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
Black screen
Try adjusting the contrast. It may be too dark. Turn the calculator on press the 2nd key and the down arrow. This is how to adjust the contrast and will lighten the screen. You can darken the screen the same way, but use the up arrow instead.
Aug 25, 2009 | Texas Instruments TI-86 Calculator
Contrast adjustment
Hello
Press and hold [Uparrow] to increase contrast or [DownArrow] to decrease it.
Try holding the the Up or down arrow. If you see that it does not do much then
Press [2nd] and release
Press [Uparrow] to increase.
Repeat the two steps in sequence until contrast is to your taste.
Hope it helps
Jun 17, 2009 | Texas Instruments TI-86 Calculator
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Difficulty reading screen
As an FYI....The arrow keys control many things,
If not in use, they control the contrast.
If ringing, it adjusts ringing.
when using handset or speaker, it adjusts volume.
Jan 17, 2008 | NEC Electra Elite 32D-1 Corded Phone
Dark screen
Turns out the little button on the top left of the device is for adjusting the contrast. Turn on the WorkPad. Press the little button. Then hold down the down button and the contrast will be adjusted.
Aug 20, 2007 | IBM WorkPad c3
Garmin Rino 120 2-Way Radio Logo
300 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
