Question about Epson PhotoPC 600 Digital Camera
Can I get the software on floppies?
I have a computer without a CD-ROM. Can I get the software on floppies?
    Master:
  • 542 Answers
A CD-ROM would initially be required to create floppy installation disks. This option will require 6 disks for Windows 3.x, 9 for Win 95, 98 and NT or 8 disks for a Mac installation.
Posted on Sep 13, 2005
SOURCE:
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
How to format acer one laptop without cd-rom?
Use an external CD rom or sometimes there is a petition file in the Hard drive to format.
Oct 19, 2010 | Acer Aspire One PC Notebook
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
Want to install xp without no cd drive or floppy drive help plz
Sure can.
Go to the BIOS menu, and select Boot from USB, or something close to it. (different companies use different terminology.)
Once that is done, use a USB CD/DVD rom and use the installation cd.
Please don't forget to rate is the answer helps
Oct 14, 2009 | Dell OptiPlex GX260 PC Desktop
How to reformat samsung s600 without using floppy disk
go to bios set up then your first to boot is the cd rom drive ok.
May 01, 2009 | Computers & Internet
IBM THINKPAD
What was the other threads name ?
What was my link?
Most drivers now only comes on CD. Without a wcd-Rom, you would have to split the drivers files into multiple floppy drive then rejoin it on the laptop.
May 13, 2008 | IBM ThinkPad 760 EL Notebook
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Cameras Logo
60 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
