Question about Refrigerators
My freezer works but the refrigerator does not cool. At times if here what I think is the compressor running. There is a motor with a fan blade attached that I do not see running, would this have anything to do with the problem?
  • 1 more comment
  • rushcalkins Sep 01, 2008
    the motor with the fan blade sits next to the compessor in the back of the refrigerator. If this is not the problem what could it be?
    IS THE CONDENENSOR FAN YOU MENTIONED NEXT TO THE COMPRESSOR/
    could the condenensor fan be the same one i mentioned and does it set next to the copressor? does run all of the time the compressor runs?
  • 2,071 Answers
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Just click below for more information;
There are 44 'Do-It-Yourselfer' stories about installing this part
Hope this may help you; Regards, VOTIT
Posted on Sep 14, 2008
  • 1,512 Answers
G'day mate
Yes,if you have a condenser fan then it should run when the compressor is running ,and may even run when it is not as well depending on the type of fridge/freezer it is. Do you have any more information on it, sounds like a commercial built in type unit. The freezer may be cooling, but to what degree. If it is only getting to -5 degrees, this is not enough and the fridge will be proportionately higher in temp. maybe even up to 15 degrees. is the fan motor seized or able to turn freely. . Is it getting supply voltage, is it a capacitor start type. if you give it a poke with a stick, can you get it to spin up normally when the compressor is running. Check these things out and we can go from there.
robotek
  • 1,031 Answers
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
  • Posted on Sep 01, 2008
    • Starnley Johnwells
      Starnley Johnwells Sep 01, 2008
      In most refrigerator freezers the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
      Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
      The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
      Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more.
      Top Expert:
    • Refrigerators Master
    • 77,499 Answers
    The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
      Sergeant:
      Champion:
    • 310 Answers
    Check this link
    http://repair2000.com/refrig.html
      Genius:
    • 1,269 Answers
    You need to replace the freon. That's definitely the problem.
      Genius:
    • 3,422 Answers
    HI,
    If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
    • Priya darshan Sep 01, 2008
      Can you let me know the make and model no. of your refrigerator so that i can give you a diagram for it.
    I have no cold air in my refrigerator or Freezer. It defrosted everything.
    Condenser Coils are Dirty
    If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
    Evaporator Fan Motor
    If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
    Condenser Fan Motor
    If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
    Start Relay
    If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
    Temperature Control Thermostat
    If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
    Start Capacitor
    If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
    Thermistor
    If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
    Temperature Control Board
    If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
    Compressor
    If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
    Main Control Board
    If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
    Jun 28, 2017 | Refrigerators
    Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
    Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
    The kenmore won't keep the fridge or the freezer cold and now its outer left panel gets hot when it runs and the heat extends all the way around to the doors. It has been running almost all the time,...
    Check the fan in the back of the refrig , which cools the compressor , for operation or blade obstruction . If not turning to keep the compressor cool , replace the fan motor .
    Nov 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Compressor cooling fan not running. Found problem based on diagnosis of strip between freezer and refrigerator being hot. How do I get the fan running?
    You will have to replace the fan motor . Maybe you can turn the blade by hand to get it started . If not , try putting a small fan blowing on compressor towards front , so it will help keep the coils cool also , until you can get a new motor . If you had given model number , I could have given you the part number .
    Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Freezer works Refrigerator will not cool down
    The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
    Apr 22, 2009 | Kenmore Refrigerators
    Freezer not freezing and fridge not cooling
    Check the back wall of the freezer for ice buildup.
    If yes, a defrost parts problem.
    Check the freezer fan. Is it running?
    If no, replace the freezer fan.
    Check the condenser fan at the compressor. Is it running?
    If no, is compressor hot?
    If compressor is hot replace condenser fan motor.
    If compressor is not hot.
    Replace the compressor start relay.
    Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
    General Electric Refrigerator
    Check the connection of the electrical harness to the fan motor. If it is fully connected and the motor still does not run replace the fan motor. The fan MUST operate at the same time as the compressor to properly cool the system. Spin the fan blade by hand with he power off. If it turns with any resistance the bearings are dry and in most cases the motor is replaced.
    Jun 07, 2008 | GE Refrigerators
    Bosch KGU32160 fridge freezer
    The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
    Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
    Not cooling
    If you still have this problem I would like for you to check to see if the fan below the refrigerator is blowing. This fan is called the condenser fan and is located beside the compressor in bottom rear under the refrigerator. If it is not running It may have a piece of paper or mouse or something lodged in the blade or it may just have bad motor bearings. If you use an exterior fan to blow air under the refrigerator it will cool again till you can replace the bad condenser fan motor.
    supertechks
    Aug 14, 2007 | Kenmore 64802 Top Freezer Refrigerator
    Refrigerator stopped working, freezer works fine
    Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
    Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
    Refrigerators Logo
    99 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
