Question about Microwave Ovens
Whirlpool microwave does not switch on - no power
Hallo everyone,
Our nine year old boy decided to open the door and use a small piece of rolled up paper to "close the lock" without having the door shut with the result that the door could not be closed anymore. However the clock on the display was still working fine.
I then used a nail to "pull back" the "hook / switch" into place so now the door can be opened and closed as usual.
However I am not able to switch on the microwave anymore, it does not respond at all; it appears to be dead. No clock, no light, no nothing ..
Meaning it is plugged in but when I press the Start button nothing happens.
I opened the device by removing the white metallic cover. On the inside located directly behind the Start button I spotted a glass fuse with light blue, orange, dark blue and brown circles around it. It seems to be OK still. Little metal wire looks fine.
Else I can not see anything wrong with the device. Is there another fuse somewhere?
Kind regards
P.S. I could not find my product in the list below. So I chose the first.
  • Microwave Ovens Master
  • 9,098 Answers
A problem with a door switch or door switch mount (like this one) will cause the fuse to blow when the door is opened or closed.
There may be a second fuse inside.
You also need to check the door switches and latches to be sure all the debris is out.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 02, 2008
Our 1.5 year old whirlpool micowave keep sending a message open close door check time microwave will not work till several tries later.
The door sensing switch is faulty. You have to replace the switch.
If you wish to get some details about Microwave oven repair ; visit the site linked here. Pull up older posts.
Jan 07, 2017 | Whirlpool Microwave Ovens
Whirlpool f1e5 fault detected, disable power to clear
just go to breaker box and turn off the breaker that powers the stove
Jun 06, 2014 | Whirlpool RMC275PV Built-in Microwave...
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwave does not heat. The power is
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 15, 2010 | Whirlpool MH7140XF Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool Control Panel Repair
model # MH6150XLQ
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
207 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
