Question about Kodak EasyShare LS443 Digital Camera
Stuck Shutter The shutter on my Kodak LS443 is stuck. Changed & recharged the battery, but no help. Anyone have suggestions on how to correct this condition? This happened once before, under warranty, when I sent the camera to Kodak for repair. They returned & said there was no problem... Hmmm?
  • 277 Answers
SOURCE: Camera
hi try turning the camera on while its trying to move the shutter HELP it! just push the shutter to its place... idont push it to hard or you will make it worse if that wont work while starting it up give it a little slap on the bottom or on the side hope it helps good luck
Posted on Apr 09, 2006
  • 12 Answers
SOURCE: Kodak Z760 Digital Camera....shutter button is JAMMED...HELP!!!
if it's only the shutter buttonl you can send it in to kodak service center;; THAT'S THE ONLY CAMERA COMPANY THAT HAS GREAT SERVICE; I should now I have this camera; after one week of having it my sister dropped it and the speakers didn't make any sound at all; I call kodak they gave me an address i send it in in a tuesday and by saturday I had it back fixed ;; for free;;; well it was in warranty.. if yours still has a warranty call them;;
Posted on May 09, 2007
  • 3 Answers
SOURCE: Autofocus problem-Kodak EasyShare C875
I can not get the camara to focas AT ALL!
Posted on May 27, 2008
  • 10 Answers
SOURCE: I push on the shutter button and nothing happens!
Have you tried to put new batteries in it sometimes when they start to die then not all of the functions will work and also cheap batteries can be brand new but not strong enough to run the functions
Posted on May 25, 2009
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Posted on Jun 08, 2009
anujpaul
  • 217 Answers
SOURCE: how to unlock the camera kodak easyshare ls443
If your memory card is locked make sure that the white tab on the left side of the memory card is in the unlock position.
Posted on Jul 11, 2009
0 characters
1 Points
Lcd screen does not show scene and photos are all black. can anyone help?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2011 | Kodak EasyShare DX7630 Digital Camera
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
My Kodak EasyShare C713 suddenly takes only black pictures and shows only a black image on the LCD in live display. Playback is fine for old pictures and movies. Can I replace the picture senor element-...
It actually might just be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Dec 19, 2010 | Kodak EasyShare C713 Digital Camera
Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
It appears that pictures are being taken with the lens cap on - when that's not the case. In other words all camera indications are that the picture is "taken", but it is a black square. I'm thinking a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 12, 2010 | Kodak EasyShare DX4530 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 12, 2009 | Digital Cameras
My Kodak Easyshare LS443 is taking black pictures
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Camera Problem
I have been reading a lot of posts from people with similar problems. Apparently, when people try to fix this camera, they are told that the parts are no longer carried and are told to buy or upgrade to a new camera. I am interested in hearing more experiences from people on this camera. I work for a consumer rights law firm and we are investigating this. You can contact me at abby1100ny@yahoo.com. Thanks, Abby
Apr 12, 2007 | Kodak EasyShare LS443 Digital Camera
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Jun 20, 2006 | Kodak EasyShare LS443 Digital Camera
Camera
Apr 09, 2006 | Kodak EasyShare LS443 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
59 people viewed this question
Top Kodak Digital Cameras Experts
Tony
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
