Key board problem with net connection
As soon as I type any word by key board the net shows problem and end the task and restart net connection, however it goes fine when using mouse with net but as I press any key it shows problem. Off line there is no problem with key board.
Stuck in log in screen
The most likely cause is you've recently installed some hardware or software, and upon restarting, the computer didn't know how to handle it. Not to worry, there are several options that often solve this type of problem. Disconnect any hardware you recently installed, such as a sound card. It could be causing the issue. The hardware may be defective or your computer may not have the capability to use it. Start the computer and wait for the Desktop to show up. If the Desktop appears to be just seconds away from showing up but never does, hold down the Ctrl-Alt-Del key combination. In the menu that pops up, choose "Start Task Manager." Select any task you see in the "Application" tab and choose "End task." This may allow the computer to finish loading. Restart the computer if the problem persists. When starting, hold down the F8 key to get a list of startup options. Select the option for "Last Known Good Configuration." Let Windows boot up. If this doesn't work, restart and choose "Advanced Boot Menu" and then "Safe Mode." Let Windows load. If either solution works, go to the Control Panel and choose "Uninstall a program." Select the last thing you installed and choose "Uninstall." Attempt to repair Windows. This may be your last option if nothing else works. Insert the Windows DVD and restart the computer. When the computer restarts, press any key to boot from the DVD. At the first menu choose your language and country and click "Next." Choose the "Repair your computer" option. Use the recovery tools option and then "Startup Repair." If this doesn't work, repeat these steps and choose "System Restore" instead of "Startup Repair" and choose a date before you began experiencing the problem. Hope this helps
Dec 27, 2012 | Samsung NC10-14GW Notebook
What do all the keys on my fijitsu siemens pc do
The Keyboard is manufacture to perform the task of typing what ever the user try to type. In Fact the question which you just type in Fixya is also because of key board.
Jul 25, 2012 | Fujitsu Computers & Internet
My Hp-620 Laptop is not displaying Wallpaper and no option for it pls help me
Do you mean your laptop shows no start menu, no desktop icons? If its seems like it booted up except nothing is shown on the screen try the steps below.
Click Ctrl+Alt+Del to get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hit the Del key while holding them. Once the task manager opens Clcik the Processes tab then click the Image Name Column heading on the left to get them in alphabetical order. Scroll down and look for explorer.exe. If you see it click it to highlight it then click End Process.
Next, click the FILE tab at the very top left of the window and select New Task (RUN). When the Create New Task window opens type explorer.exe and press ok. Your start menu, task bar and desktop icons will start appearing and populating. if not that means a virus has hidden your files and folders.
If it is not resolved try the steps below:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 06, 2012 | Computers & Internet
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
My loptop is honging off
If your laptop is hanging while you are working, press this combination keys:
Ctrl Alt Del.
If you are using windows XP, it should automatically take you to task manager.
But if you are using windows vista or windows 7, it would show you options, of which you are to select 'task manager'.
End the tasks the are not responding by right clickin it and selecting 'end task'.
If that task still refuses to end, still in the task master pane, go to 'processes'.
Select the processs running the nonresponsive task. Eg, if internet explorer is the non responsive task, the process would be 'explorer.exe'.
End that process.
If it stil doesnt work, then select 'end all processes', and restart the system.
Hope this was helpful?
May 14, 2011 | Sony VAIO Notebook
If you have the strong virus you can not not open flash drive.
Follow step>Go another PC which is running well, If all the hidden file and protected system file can see in that PC think that is well in condition. But please don't connect the usb pen drive.Now you stop the autorun .Follow all the instruction.
How will you confirm?
Follow the steep.
Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT and an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
If , still there are no hidden file in drive C:
Think your computer has affected by serious virus because to protect the system file
microsoft manege all sysy file as hidden.
When you can see all hidden file think Ok .
If your another PC is well, after examine all the steep, do all the steep now
>start>program>accessories>system tools >system restore >set earlier date. If you have the strong virus you can not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task manager>run type ms config >enter, it will be open windows>run type gpedit.msc> enter ,it will be show.>run type regedit enter ,it will be open .think your another pc run in ok condition. Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
Now auto run program off. you can access easily.Now you can insert the pen drive and delete unnecessary file or format.Now you can format or open your pen drive.
Hope it will help you.
Feb 13, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't open
1. First go to Task Manager and end process “firefox.exe”.
2. Go to programs -> Mozilla Firefox -> Firefox (safe mode)
3. In the check list select for defaults and disable all add-ons.
4. Click make the changes and restart.
Scan ur pc with maleware.
The another solution is
· Go to 'Run' and open 'cmd'
· Type 'netsh' in command console then press enter
· Then type 'winsock' and press enter and then type reset
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
· Find the Key :
· Name: EnableDCO and set
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner to solve it.Download reginout to sove the problem
Aug 27, 2010 | Mozilla Firefox
Installed a new hard drive. Now the system tells me it can't find the operating system. I checked the connections and they seem to be connected ok. Any ideas what the problem?
if it is ide haed drive you have to make sure that the red wire on cabel is on pin 1 as well as board ok check the power connections as well
Apr 16, 2010 | ASUS A7N8X Motherboard
How do i unlock a panisonic laptop without admistrated password
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progressbar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press <Shift>+F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press <Enter>.
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
Mar 22, 2010 | Computers & Internet
My neice has an acer aspire 5517. Turned it on and the screen is blank, no start menu or icons. How can I fix this?
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
