Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee is coming out weak
The water is coming through fine but the coffee is weak in color. I have cleaned all parts and it still comes out like the color of tea
  • 8,596 Answers
Make sure you are not using the paper filter and the permanent filter at the same time. Make sure the chute undernetah the grind basket is clear of grounds, moisture.
Posted on Jan 09, 2009
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Feb 11, 2014 | Keurig K75 Platinum Coffee Maker w/78...
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
The coffee is very weak. Have tried several different coffees but the same with all Brands. Have cleaned the top were the water comes out. Have run several cycles of water through it but coffee still is...
Make sure the 'vacation' switch is turned on. In addition to the warmer switch on the front of the unit, there should be another switch located on the side/rear of the coffee maker. If that is turned off, the water won't be pre-heated, and you end up with luke-warm water going through the coffee during the brew cycle. If that is not the problem, then there is an issue with the tank heating element and the unit will have to be repaired.
Dec 12, 2010 | Bunn NHB Coffee Maker
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
WE have VPR that is making weak coffee.
Hello. Have you checked your temperature of the water? If it is not hot enough, 185 to 195, it will not extract the coffee properly, causing a weak brew. Putting the spring through the spray tube does not necessarily clean the whole water brew system, and you could still have a flow problem to the sprayhead. You can check it, just pour in water, no coffee or filter, the funnel in place, a pan or something to catch the water, and while it is brewing, with a flashlight, pull down, or forward enough on the funnel to look at the spray head, there should be 5 or 6 streams of water coming out of the sprayer. If it is dribbling out, and down the sprayer, or not a decent flow from the holes, you still have a blockage somewhere. You can go here to get a parts manual for your unit, to see how things come apart etc..
You may just need additional cleaning, if it is bad, it may require chemicals.
Hope that helped, and thank you.
Mar 19, 2009 | Bunn NHB Coffee Maker
My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Mar 18, 2009 | Keurig B60 Coffee Maker
you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
Jan 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
425 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
