Question about Cell Phones
My phone switches off on it's own and will not turn back on.
When I go to turn my phone on it will not switch back on. I have tried taking the battery and sim card out, i have also tried charging it but it does not work. also when it does work the screen turns black and the keys lights turn off. i have only had this phone since february and i have not dropped it once.
  • Shrimpz Apr 14, 2009
    I have the same problem.. i have brought 3 new battery and they work for a couple of hours and then the phone turns off and does not charge and will not turn on what should i do?
Clean the whole batterywith cotton bud.
Posted on Sep 02, 2008
Hi, my phonre is froze on the huawei picture, after trying to reset it, how do i fix it, thanks
Don't switch off the phone but take out the battery and sim card , wait for a few minutes then replace sim card and battery , switch on and see if that's solved the problem . If not take back to the shop
Nov 20, 2014 | Huawei Cell Phones
My nokia 7610 got hang while browsing net.Then i switched-off the phone.But now it is not getting switched-on,when i press the power button the display becomes white for some time and then automatically...
may need servicing, but try to take out the memory card and the battery and SIM card. After that, press the power on switch for about 15 seconds. After that, try to put the battery back, make sure it is still charged, then turn on the phone again. If this works, you may turn it off again to place the memory card and sim card back and use your phone again.
Sep 08, 2011 | Nokia 7610
My phone turned off yesterday n now won't turn back on at all. What do I do I need to use it today
Try these few simple steps.
1. Remove battery.
2. Wait 30 seconds then replace battery
3. Plug in your phone charger.
4. Leave for 10 minutes.
Now try to switch on your phone.
If it doesn't switch on, take back to where it was purchased.
It may just be a charger problem but it could also be charger port or phone hardware.
Jun 17, 2011 | HTC Desire Cell Phone
My phone has power but doesnt switch on
try taking your battery out then put it bak in hold red phone on cell then wait if it does not work take it sto your phone company
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
My phone keeps on switching off and then it doesnt switch back on. to switch it on i have to put it on charge even though it is full charge.
Try this simple solution first, if not, I will provide additional solutions.
1. Turn off your phone.
2. Take the battery out.
3. Take the sim card out.
4. Wait thirty seconds.
5. Replace sim card.
6. Replace battery.
7. Turn phone back on.
That should fix your malfunction. I've had that problem numerous times in the past. I hope it helps! If not, let me know and I will do my best to come up with other solutions for you.
Please rate FixYa!
Dec 28, 2008 | i-mate JASJAR Cellular Phone
Restart??
Below are some helpful tips on what to do if you cannot turn your phone on. If, after trying the solutions below, your phone still does not switch on, please take it to your nearest service center.
  • Press the on/off key for a minimum of 10 seconds to switch the phone on.
  • Make sure that the battery is charged.
  • Sometimes the battery must be removed to allow dust, dirt and corrosion to be cleaned from the connectors on the phone and battery. You can clean the connectors with a soft brush, cloth or q-tip moistened with any type of unflavored, colorless alcohol. Make sure the battery is totally dry before you put it back.
  • Also, check for damage to the phone connectors. If you have an original Sony Ericsson battery and your phone says "alien battery", the cleaning procedure may help you correct the problem.
  • If your phone has a Memory Stick™, remove the Memory Stick and try to switch the phone on. If it works, please take your phone and Memory Stick to the nearest service center.
  • If your phone vibrates continuously when you try to switch it on, please try to do an update using the Sony Ericsson Update Service.
if it keeps doing that i would take it to the store and get it looked at and see if there is a problem with the software
Jun 13, 2008 | Sony Ericsson K550i Cellular Phone
My k610i just white screen
Try tehse steps
1. Switch off and switch it back on ,
2. Switch off and take out battery , when battery is out , press power on button for 30 secs and then out battery back again and switch on the mobile. This process is known as releasing flee power.
3. If still does not work, check whether the SIM is properly connected, take out SIM and put it back again and then check.
f still does not work then contact , the phone manufacturer, phone has to be reset or its not loading up properly and says inactive SIM , u can also contact the people whom u pay for the phone bills and check whether SIM is active or not
Feb 21, 2008 | Sony Ericsson K610i Cellular Phone
Wont Turn on
while charging your phone try to switch on your phone .or just try to switch on and switch off your phone 3-4 times continiously even if dosent work take it to the authorised service center
Dec 26, 2007 | Motorola Mobility V365 Cellular Phone
Cell Phones Logo
155 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
