Question about Epson PhotoPC 600 Digital Camera
My computer only has a 25 pin serial port. How can I connect the camera?
    Master:
  • 542 Answers
If you only have a 25 pin serial port available, you can use a 9 pin - 25 pin adapter to connect the serial cable from the camera to the computer. Another option is to add an addition serial interface card to one of your card slots. These should be available at local computer stores.
Posted on Sep 13, 2005
Printer adapter from serial 25 to usb printer
Frequently the 25pin plug on a PC is a parallel port, not a serial port. Perhaps it is this you mean.
Nov 23, 2013 | Computers & Internet
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Serial port on HP Laserjet 4M Plus
buy the adaptor for this these ports are called lpt ports they make adapters to run down to size
they also make a lpt printer port switch this is connected easy connect from printer to switch one printer cord then buy 2 other printer cords to hook to other computers
this is not a converter this is a switch
the printer cords can either be made on spot at most computer store or bought from fry's electronics they always have these in stock the proper lines your looking for
May 17, 2008 | HP LaserJet 4 plus Printer
Can I use the Fun! Flash 640 with a USB port?
A 9-pin serial connection must be available on your computer to connect a PhotoMAX Fun! Flash 640 digital camera. This camera model does not have a USB driver, so a USB-to-serial adapter will not function properly.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
USB port with the PDC 640 camera?
The Polaroid PDC 640 digital camera connects to an available 9-pin serial port only -- it does not support the use of a USB/serial converter. However, you can use a SmartMedia Card Reader with the camera's reremovable memory to download the images via the USB port to your computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Why can't I connect the PhotoPC 500 to my Gateway 2000 computer?
Some Gateway computers have their 9-pin serial port or the second serial port disabled. For instructions on freeing and enabling the serial port, please contact Gateway's Technical Support.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Cameras Logo
46 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
