Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore direct drive model 116 31912100 lost vacuum
Replaced bag, hepa fillter. Brush rolls, but no suction. What is the problem here and how can I resolve it. Thanks. Ed Cruz
  • Anonymous Sep 04, 2008
    intake hose cleared, new hepa filter, cleaned motor safety filter. Vacuum made a short roaring sound then motor quit. Is the motor dead or fuse in the motor compartment burnt out. What is the function of the protector.
    President:
  • 1,673 Answers
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Posted on Sep 04, 2008
Why is there no air blowing into the dust bag ?
You can purchase the replacement kenmore ef1 filters from Govacuum with an exclusive 11% discount coupon for Fixya.com readers, use code: FIXYA11. We also offer free shipping over $35.
https://www.govacuum.com/products/kenmore-ef-1-exhaust-hepa-filter-2-pack-similar-to-86889-40324-ef1-panasonic-part-mc-v199h-by-zvac
Jeethu
Govacuum Team
Sep 22, 2014 | Kenmore 31913 Progressive Direct Drive...
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
Kenmore progressive vaccum lost suction
For the canister-style vacuum with the long hose, you can't see all the way thru it, since the plastic fittings on the ends are curved. Mine was clogged - I mean, really clogged! Others have suggested using a high-powered air compressor to blow it out, but I augured out my lint/hair/straw/other-unidentifiable-stuff clog with a manual (hand-crank) home sink/drain auger. Worked like a charm! Use a small mirror (like a dental mirror) and a flashlight to see a little ways into the hose if you want. Finally, run the auger all the way thru to make sure you push out anything you couldn't spear and pull out.
Oct 14, 2012 | Kenmore 31913 Progressive Direct Drive...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Load noise at start-up goes away after a minute, but there is no suction.
If the brush roll and motor runs and sounds ok, then that is an indication of a clog, either in the hose or the dirt inlet down by the brush roll. You should have a years warranty on this, if you can't figure it out, then take it into Sears and get it repaired.
Apr 15, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Mar 24, 2008 | Kenmore 31912 Progressive Direct Drive...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Owners manual
remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Mar 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
757 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
