Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Problem for Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner...
Electrolux oxygen vacuum
By poinsie on Sep 01, 2008
the power wand seems to have a short, the light flickers and the power comes and goes. the suction is fine when I remove the power wand.
Same Problem
Nov 16, 2008
-   I have the same problem. Purchased new wand. Still does same thing.
I think it's in the hose handle that powers the power head.-   Guest
Solution #1
posted on Nov 07, 2009
Not Rated)
dirtdoc
Rank: Apprentice
Rating: 88%, 2 votes
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Was this helpful?
Yes
No
Solution #2
posted on Nov 28, 2008
Not Rated)
MarkSA
Rank: Apprentice
Rating: 0%, 0 votes
It is not the wand that is the problem - it is the joint between the flexible hose and the handle. Turn this and the head will start to work again.
Was this helpful?
Yes
No
Popular Solutions for Electrolux EL7020A Oxygen 3
Questions and Unsolved Problems for Electrolux EL7020A Oxygen 3
Do you recommend Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum?
Answer
Answer
ive changed the filter and the bag. but basically i plug it in and it shuts off after a minute.
Answer
power sweeper intermitantly stops working like it has a faulty connection
Answer
We got a refurbished Oxygen vacuum today and it vacuumed fine for about 2 minutes. Then the... (More)
Answer
The bag in my electrolux oxygen 3 (4 years old) is difficult and sometimes nearly impossible to... (More)
Answer
The brush roll is making loud noise the bushing that hold the brush roll is busted I need a new... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , AK
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
