Question about Ruud UBHC Air Conditioner
Ac will not cool off
The ac started not to cool during the day and would be nice and cold at night. The AC man stated that we were low on freon. So we had him add freon and clean the coils on the outside unit. Since he placed the freon, there has not been a change for the better if any thing its hotter. What did he do wrong?? Help!!!
  • amieandmae91 Sep 01, 2008
    thanks a bunch! he never cleaned the inside unit. the line that has freon in is cold and sweaty so I will have them come back and check again. thanks again!!!
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
There are only 2-choices for this problem,,, 1= low on freon or 2-low air flow across the indoor coils which can be caused by dirty filter--- dirty fan blades and last but not least , dirty or plugged inside coils. After the unit has been cleanned , then he's suppose to check the freon last..
Posted on Sep 01, 2008
97 Plymouth Breeze won't blow cold air due to freon leak.
Your AC system is a closed system, so the fact you have to put more Freon in, means there is definitely a leak. I would check it out with a mechanic.
Apr 26, 2015 | Plymouth Cars & Trucks
I have a question. I have a Kia Rio 2008 and since a few months now, i'm experiencing problems with the ac of my car. My AC is only cooling when the car is not driving, or when the weather is not a hot...
The noise is probably the compressor. Maybe the belt could be loose or worn. You may be low on freon. Start with the easy one, check the belt, then freon. Good luck!
Jun 20, 2014 | Cars & Trucks
Air conditioner electric circuit
Try disconnecting battery for two minutes to reset the system. Then start the car and check a/c operation.
Dec 22, 2013 | Oldsmobile Cars & Trucks
Compressor keeps kicking off 1999 Buick Century AC
Your ac system is most likely low on freon, or the cooling fan is not working.
When you turn on the ac the cooling fan should stay on.
If it stays on then you are low on freon.
Nov 23, 2011 | 1999 Buick Century
Ac cools at night but during day doesnt when the car has been driven around
Have the AC system check for proper charge. It sounds like you may only need more freon.
I hope this helps.
Sep 03, 2011 | Jaguar X-Type Cars & Trucks
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Ac system does not get cold
you should go to a mechanic and check the A/C if the freon id low it won't cool , some time at mornig it give you the semsation that is cooling but probably not..
Aug 01, 2009 | 1999 Volkswagen Cabrio
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
2003 Chevy 1500HD (6.0) Air Conditioner Will Not Cool
a refurbished compressor should be fine and will be cheaper than new, your should also replace the orfice tube (expansion), and the dryer, and the seals at the connection points.
Mar 25, 2009 | 2003 Chevrolet Silverado 1500
Ruud UBHC Air Conditioner Logo
185 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
