Question about Sony KV-35S42 35" TV
HELP! Our Sony TV started taking longer and longer to warm up for the screen to come on. At first, it took longer and longer but it came on and worked fine, the picture was great. Over time not only is it taking longer to warm up for thepicture to come on but the screen has also begun to flash while watching it. It's get worse and worse, to where you can't watch a program on it. I talked to a service tech and he said it could be the picture tube. Is there anything that you know of that we can do at home to fix this problem or is it a service issue for sure? Could it be something besides the pic tube and worth fixing?
  • dwaine01 Sep 26, 2008
    Mine
  • ecarson Oct 01, 2008
    is it something we can fix ourselves or do we have to take it in to a repair shop?
    Champion:
  • 252 Answers
The problem of your tv is the CRT socket replace the CRT socket it with a new one and your tv will fine.
Posted on Oct 01, 2008
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
My sony xbr5 flickers until warmed up
brennanrp, I hope you purchased a warranty on your TV. My 46 in xbr-5 was doing the same thing. I called the store I bought it from and they took it to a repair shop. The panel inside, basically the inner workings are faulty and Sony has put an extended warranty on it. Get it looked at as it will only get worse. Soon you will probably be seeing some vapor like images across the screen if you have not already. the lines starting showing up even after extended viewing times.
Oct 14, 2009 | Sony Televison & Video
TV Model # C27A24T about nine or ten years old. TV
Bad grounds and bad caps will cause the problems in this tv. You will need to replace several caps and resolder the tuner itself and that means taking the tuner out in some cases and rework it. This is very time consuming and needs great care not to destroy the tuner. And reinstall the tuner to the board. You need the cap check to locate bad caps and visual to see bad grounds on any Ic on heatsinks. If you are a do it yourselfer fine.. If you cannot do this I would just replace the tv.
Oct 11, 2009 | Zenith C27A24T 27" TV
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Screen tuens blue them tv turns off
NOT GOOD NEWS... IT SOUNDS LIKE YOUR BLUE CRT IS SHORTED. THE ORIGINAL PART IS N.L.A.(NO LONGER AVAILABLE) THEY DO MAKE A GENERIC REPLACEMENT, BUT I DON'T THINK THEY ARE AS GOOD AS O.E.M.
YOU CAN TAKE OFF FRONT OF T.V. AND ADJUST THE SCREEN DOWN ON THE FOCUS BLOCK. IT IS THE BLACK BOX WITH 6 ADJ. ON IT 3 ARE FOCUS. 3 ARE SCREEN . TURN THE BLUE ALL THE WAY DOWN , THEN WITH THE BACK OF A PLASTIC OR RUBBER SCREWDRIVER HANDEL YOU CAN TAP ON THE NECK OF THE CRT, NOT TO HARD. SOME TIMES YOU CAN CLEAR THE SHORT OUT OF THE CTR. IF THIS WORKS LET THE SET WARM UP FOR 10-20 MIN. THEN TURN THE COLOR ALL THE WAR OFF, THEN SET THE BLUE LEVER UNTIL YOU HAVE A GOOD BLACK AND WHITE PICTURE. BE CAREFUL NOT TO TURN IT UP YOU CAN DAMAGE THE CTR IF THE LEVEL IS TO HIGH. ERROR 8 IS A.K.B. ERROR THAT MEANS THE CRT'S ARE DRAWING TO MUCH CURRENT.
DON...
Nov 12, 2007 | Sony KP-51WS510 51" Rear Projection...
Overpoewering red
Every person I know who purchased this very expensive unit has had this problem early in the life of the TV. Sony is no help. Sony will suggest you take it to a repair facility. Sony from years ago is not the Sony of today. It was expensive to purchase and it will gouge you with repairs. Your choice. I eventually discarded my set and purchased a JVC. These rear projection TV's are garbage and Sony knows it and they dont care. Seems like the last for only a few years and then major problems occur. My solution replace it!
May 15, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony Gurus! My set has sound, screen takes long to come on.
I will suggest you put the screen control back to where it was,the unit has a lot of loose conections in the power supply,horizontal driver transformer and possibly crt board,if you keep using it like this it will go dead completly and the repair will be more expensive,be safe and call a person who is qualified and get an estimate.
Sep 18, 2006 | Sony KV-32V68 32" TV
Sony KV-35S42 35" TV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
