Question about Epson PhotoPC 600 Digital Camera
Setting up the camera on my Gateway computer
I'm having a problem setting up the camera on my Gateway computer. What should I do?
    Master:
  • 542 Answers
Your PC serial port is possibly not setup properly causing it to not recognize the camera. Gateway has information concerning their special COM A port on some model computers and how to set it up properly for external devices. Basically, you need to hit F1 at boot to enter the BIOS setup utility. Go to Advanced / Peripheral Configuration / Serial Port 2 then hit Enter. Then Disable. Go to Serial Port 1 Address and hit Enter. Change it to Com 2 (2F8h). Save the settings and exit. After Windows 95 boots, go to Control Panel / System / Device Manager / Ports and delete the serial port 2 with the (!) -- exclamation mark. Go back to Ports and select Properties for Com 2 / Port Settings and change the speed to 38400. Now go into Easy Photo...select Com2, and set the speed to 38400. Test the camera by downloading the snapshots.
Posted on Sep 13, 2005
Trendnet639gr connection to ip cameras address
Almost everything that would normally connect to the computer, such as keyboards and mice, have become wireless for a good reason: fewer cables and more mobility. If you want cameras that integrate into your local network and do not involve a mess of cables, wireless IP cameras are the best solution. They are very simple to install, and all you have to do is open your browser on a computer in your network to configure them.
Open up your preferred Web browser. Find the IP address of the camera. This address must be written somewhere on the device or on its operator's manual. Write the IP address of the camera on your browser's address bar. Setting Up Security On the page you arrive at, set the camera name to something you would be able to distinguish on your network. Browse the interface until you find a menu where you will write an administrative ID and password. Type any ID you would like to have and a password for the ID to log in through. This is necessary so that others cannot tap into your camera and invade your privacy. Setting an IP Open the browser interface for your camera (see the section called "Getting to the Web Interface"). Go through the menus until you find where you can set an IP for your camera. Manually assign an IP that you will recognize for your camera, and set the default gateway to your router's IP address (find this out by looking at your router or its operator's manual). Make sure that the IP of your camera is not already used by another computer.
Enhanced Dynamic DNS
http://www.no-ip.com/
Apr 18, 2013 | Computers & Internet
FORMAT ERROR shows up in the window. Cannot take pictures, or review shots. Gateway DC-T50 Digital Camera The problem occurred after I tried to hook it up to my Mac computer to download pictures which I...
Remove the batteries wait a few minutes. Put fresh batteries back in and turn the camera on. This resets the camera.Then remove the memory card from the slot from your camera. Then insert back and check you will not be getting this error.
If still there is some problem, take the memory card out and copy the pictures from the memory card to system and then format it. Insert the card back to the camera. You won't get the format error.
Hope this helps.
If you still have any queries feel free to ask us.
Shane
Feb 18, 2011 | Gateway DC-T50 Digital Camera
All of a sudden, my gateway laptop nv52 screen dims on AC and brightens on battery power. It must be a key combination because I suspect my cat walked across the keyboard.
Try this,press function(Fn) and the power up button/down button. that will fine tune the middle setting your laptop. the middle setting is one of 3 settings, you need to press function and f8 to switch between lowest, middle, and high. the middle setting can be any setting you like and will be the default setting when you use your computer with a chord or without it.
Thank You
Jan 04, 2011 | Gateway Computers & Internet
Unable 2 get grps settings
Main Menu select > Services > Data Account
set the current GPRS setting properly.
If you sill not able to figure it out you can get the SMS setting from network service provider and you can save the setting so that settings by default account to you.
To make your GPRS working you should first need the settings for it.You cannot set it.Your network provider should give the default gateway address for it.Then only you can use it.
If you already have set the setting and now if it is not working because the network service provider would have changed the gateway Ip address.
Dec 08, 2010 | Dual Electronics CECT P168 Cellular Phone
When I take indoor pictures, they always come out with an orange color. I would like to know what caused this.
Incorrect white balance. I'm not familiar with your camera...check your manual to see if you can change the white balance setting.
Oct 30, 2010 | Gateway DC-T50 Digital Camera
After using my laptop(Gateway NV53) for about 5-10 minutes the screen will turn black or the screen will freeze. Non of the buttons works after this and the only way for me to reboot the laptop is to pull...
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power
setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc,
Jul 01, 2010 | Gateway NV5387u Notebook PC
Gateway MX6447 system fan doesn't come on during normal use; the
On my computer, in Control Panel/Device Manager/System Devices I find five (five!) ACPI Fan devices listed. None of them have any adjustable parameters. However, in regedit I find two settings for each: 1) Slow the processor before increasing fan speed (this is ON), and 2) Increase fan speed before slowing the processor (this is OFF).
So...on my computer I am going to say there is no registry setting to make the fan run all the time...can't say that's also true for yours.
Apr 10, 2017 | Gateway MX6447 Notebook
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
Setting up the wriless network
You need to have a cable going from the modem to the gateway, and then another wire going from the gateway to the computer.
Oct 04, 2007 | 2wire HomePortal 1800HG Router...
Cameras Logo
55 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
