Question about Kodak EasyShare DX4530 Digital Camera
Problematic Camera I have a EasyShare DX4530 which has suddenly started acting funny. Here's the sequence of events: - power up works fine - lens comes out ok - green light glows steady, ready for a picture - picture takes fine - green light doesn't turn on again - no amount of pressing the shutter button will bring the green ready light back - pressing the SHARE button a couple times (sometimes 2, 3, even 4 times) will move thru the share sequence and then finally exit that function, turning the green light back on. - picture can then be taken, but the whole SHARE button exercise must be executed in order to take another picture. I tried reformating the memory card, removing/replacing the batteries with fresh ones about 4 different times, looking thru the menu for setup or configuration issues, reading the book, and going online to Kodak's troubleshooting and FAQ webpages --- nothing helps. Anybody experience this behavior? Must I send the unit in for servicing? I have the extended warranty so it will only be painful, but not hopeless. Thanks.
  • Anonymous Mar 27, 2014
    The unit powers up but it misreads a whole different book tha n the one inserted. The styles only recognizes the green go circle at the bottom of the page instead of the top. Also the LeapPad is operating as if by memory of a whole different book altogether and when you turn the page it changes again to a whole other interactive book? Would like to know if it is repairable and what the solution is.
    Sergeant:
  • 255 Answers
I just discovered that the real problem is a STICKY SHUTTER BUTTON, staying down after taking a picture. This prevents the green ready light from coming on until I jiggle the shutter button. It has actually started to be hard to press, making a definite clicking sound as it goes down. I can even feel it catch on something. If I move it around a bit, it will eventually come up, allowing the ready light to reset. Can this be cleaned? How about adding a drop of WD40 or something? Anybody ever take one of these apart? Any tips as to how to do it safely??? Thanks.
Posted on Sep 13, 2005
Menu button doesn't work on kodak easyshare dx4530
Perform a power resetting and check the operation.
Jun 23, 2012 | Kodak EasyShare DX4530 Digital Camera
Why won't my camera turn on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into more detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Nov 10, 2011 | Kodak EASYSHARE Z1285 Digital Camera
My 70-200 is acting up. When mounted and shooting,
yes- the internal mechanicsw of hte lens pull from the camera body - are the contacts between the lens and body clean? your probably going to need to send the lens in for repair. :(
Mar 07, 2017 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
If i go to favorites it works fine switch over to the camara it starts to work the screen goes off and stops
I may be able to help with your Kodak EasyShare Z740 that works in favorites but turns off in camera mode. This is a common problem.
This is either caused by a problem extending the lens, or a computer brain problem that is reset with a button press sequence.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Stops taking pictures
I have the similar problem, I turn on the camera and after the lens comes out , red light blink all this time, and suddenly it powers down without retracting the lens back in.
The battery are fully charged AA 2400mah / 2650mah Duracell at 4.0 ma with load test. I was wondering if there is any circuitry problem.? Any experts in digital camera electronics please respond? Trick: To bring back the lens back in for safekeeping i trik this, i turn it on while it is reading the memory etc and after a sec or two i turn the knob to off, this way lens goes back inside.
I have read other brands also have their cameras lens sticking out and never going back inside.
Feb 19, 2010 | Kodak EasyShare DX4530 Digital Camera
Kodak easyshare dx4530 turns on then off
Hi there.
90 percent of the time when the lens malfunctions, it's due to grit or dirt in the lens mechanism. If you stored your camera in a camera bag, while you used the other camera, that could be your problem. Camera bags are great for holding dirt so it can get in your camera.
When the lens can't move, it may cause the camera to shut down. To fix this, use an air compressor. Put the nozzle to the camera and blow air into the space between the camera and the lens. Blow it out real good and try it again. You may have to repeat the process a couple of times. Hope this helps.
Rob
Mar 03, 2009 | Kodak EasyShare DX4530 Digital Camera
Inner lens
This is a workshop repair job at Kodak or a new camera.
Usually these devices are not economic to repair.
Dec 28, 2007 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
159 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
