Question about Fedders A6X05F2D Air Conditioner
Freezing Up The air conditioner is freezing up and not cooling.
My air condition keeps freezing up everytime I turn it on. it is ice up.
Posted on Apr 28, 2009
    Brigadier General:
  • 5,158 Answers
Sounds like air is not flowing properly thru the a/c. if there is a filter you can pull out remove it and clean it.
Robert
Posted on Sep 01, 2008
Ice on coils of heat pump not cooling
Which coil?, indoor or out? Indoor coils freeze due to clogged filters, low freon, blower motor not working. Outdoor coil freezing could mean, in rare cases in cooling mode, reversing valve not shifting.
Oct 02, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
Ac unit is not cooling, the part on the inside keeps freezing up after it is frozen the air blowing is not cool. Sometimes there is a knocking sound from the compressor.
Freezing of the evaporator is caused by low air flow (fan problem or dirty filter),low refrigerant charge or leak. I would suspect a leak (noisy compressor) because the compressor lubricants are in the refrigerant.
Sep 29, 2013 | Heating & Cooling
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
GE AZ58H12DAD The unit is freezing up and will not cool.
Freezing and no cooling is a common sign of low refrigerant. You will need a technician to repair and recharge it.
Apr 10, 2011 | GE Zoneline AZ58H12DAD Air Conditioner
My air condtioning unit is a GE unfortunately I can't se what btu but ev ry our the coil freezes and its spitting out water. Room size.
clean the coils its freezing up because the air flow is restricted because of dirty coil or filter after cleaning the coils and it still freezing up then it will need some refrigerant aka freon
Aug 19, 2010 | GE Built-In Room Air Heat Cool Air...
My lg lb1200er is freezing up how do i fix it
Take the front off and replace or clean the filter. Get a soft brush and remove the lint from the coils. If it is severely dirty you can buy some cooling coil cleaner
Jul 16, 2010 | LG LB1200ER Air Conditioner
Freezing up
The number 1 reason for freezing is not enough air flow across the evaporator (inside) coil. Check filter, and try vacuuming the coils. Use care to not mash or bend the fins. If this does not work, then perhaps a wash with a soap solution and water hose will do the trick for you.
Jun 29, 2009 | Kenmore 75085 Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Fedders A6X05F2D Air Conditioner Logo
204 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
