Question about Kenmore 62882 Electric Dryer
No heat coming from Dryer
I am having a problem with our dryer.Our dryer turns on but there is no heat coming out. Can you give me some solutions?
Thank you
  • Anonymous Oct 20, 2008
    mine too.. modle number: 67902790-67902
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Theres no heat coming out of my dryer. i have checked gas line no solution? can you help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 31, 2011 | Dryers
My dryer blows heat and then blows no heat, the top, back of the dryer gets real hot, any solutions
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jan 17, 2011 | Frigidaire Electric Dryer
The heat comes on but the barrel does not turn. the dryer is only 3 yrs old. what gives?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 14, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The dryer is not heating. The Heating element turns on and some times the flame comes off the then shuts. Most of the time the flame won't turn on
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Kenmore 24032\24036 Top Load Washer
Heat comes and goes, most of the time no heat but sometimes heat comes on
heatman101
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
ELECTRIC DRYER WON'T HEAT, TURNS ON , BUT WON'T HEAT.
If your dryer runs but doesn't heat, verify that all breakers (or fuses) are fine. If one is blown, the dryer may still operate but not heat.
Another common cause of a dryer failing to heat (or only partially heat) is a faulty element. You will need to replace it.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Roper RES7646KQ Electric Dryer
Dryer won't heat. Will blow air and drum turns but no heat. Manual sent to me does not give troubleshooting solutions. Please help Pattie
heatman101
May 13, 2010 | Amana ALE956EA Dryer
Dryer won't heat. will blow air and drum turns but no heat. Manual sent to me does not give troubleshooting solutions. Please help Pattie
If you have a gas dryer then check out this tip...
If you have an electric dryer then check out the tips at the bottom of this tip...
Heatman101
Mar 22, 2010 | Amana ALE956EA Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Kenmore 62882 Electric Dryer Logo
2,048 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
