Screen doesn't light up
I have the same problem as most with my N3010 lifebook with fujitsu. i dropped the computer and it broke the screen, i've baught the complete screen and had it replaced and the ribbon. i've baugth a new inverter and new back lights nothing works. if i hook up a monitor to the computer it works great. i can't find the right numbers for my inverter it has been changed a few times because we could never get one that worked with it. the one that is in now powers the computer but no light. i've put a new one on and the floppy disk looking icon on the screen lights up ( the 4th icon on screen next to the battery lights ). do you have any suggestions?
Fujitsu N3010 lifebook internal mouse will quit working after a few minutes after boot up
Do a full anti-virus scan of your system, if okay! try a system restore bring computer back in time before this happened.
Apr 20, 2012 | Fujitsu Siemens LifeBook N3010 Notebook
Need to replace a keyboard on a Fujitsu Lifebook N3010. Dropped beer on it. Now some of the keys aren't working. Would like detailed inst's on how to crack this comp open.
I have stripped many laptops down and to remove keyboard is reasonably complex and replacements are also expensive. Dowload a manual off the net is the best and follow instructions to the letter. Ther isnt enough room here to describe the procedure.
Nov 20, 2009 | Fujitsu LifeBook N3010 Notebook
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
How I can down load audio driver for N3010 lifebook Fujitsu?
http://www.fujitsu-pc-asia.com/drivers/spring05/n3510/audio/winxp/n3510_audio.zip
Hi here is a link copy and paste into top of broswer i know its not the right 1 but ive been on there web site looking for your laptop and could not find it just try to install ok most likey they will be same audio chip find all info at fujitsu hope this helps please rate
Is the back light bulb replaceable in the Fujitsu Lifebook N3010
yes it is and a suitable place to find it is Ebay or search it by part number on google, as NEC will not have the display for it.
Jun 26, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Fujitsu Lifebook N3010 boot error
Do you have the original Driver and Application (DAR) CD? If so change your BIOS setting to boot from CD first and boot from the DAR. This will take you to the backup partition DICE (Disk Image Special Addition) on your hard drive. This will allow you to restore your system to the original drive image configuration. You will loose all your data!!!!!!!
Mar 10, 2009 | Fujitsu LifeBook N3010 Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Computers & Internet Logo
129 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
