Panasonic DRM E55PC Run good for 2 years. Suddenly completly dead (nothing works) AC cord OK fuse OK power switch OK 5 volt dc at power switch.
  • 4 more comments
  • henrih2 Sep 01, 2008
    problem nothing works
    so what is the problem with the power supply
    where can I find manual for that,
    the site you gived as no manual for that (DRM E55PC)
    this site do not have manual to download
    how to check the power supply?
    you sent me on a site for users manual,
    I need a site to download a service manual
  • 10,594 Answers
an easy way to sort out the problem area in dvd recorder is arrange another same model recorder and exchange its power supply for confirmation. If power supply board found ok, next board have to confirm and so this you will locate exact board or section of defect.
Posted on Sep 01, 2008
    President:
  • 1,952 Answers
Check ur 5v component like transistor
  • 1,800 Answers
Its defintly the power supply/transformer issue try to replace it with the proper one with same voltage and amper u can get it from separate electronic parts stores and websites!!
plz rate this post
i ve already face same issue with my own!!!!!!!!
  • 6,487 Answers
Try checking this link for the user manual http://www.retrevo.com/s/Panasonic-DMR-E55-DVD-Players-review-manual/id/312dj185/t/1-2/
Hope that helps........
    Genius:
  • 1,269 Answers
The main board needs a general diagnosis. Check any burned components like resistors, transistors, capacitors, ICs, transformers and other internal components. Since you said its not turning on, you may need to start checking the power supply section like the transformer.
  • Michael Galve
    Michael Galve Sep 01, 2008
    Trace the power cable going to the unit's circuit board. That power cable is definitely connected to the power supply. Normally you can see a transformer there that is connected to the power cable. Check if that part or section has a burned components or parts.
  • 1,879 Answers
Service manual here but you gotta pay for it
manual link
  • monk3ybidzness
    monk3ybidzness Sep 01, 2008
    why pay for it ? cause panasonic ain't giving out any of their service manuals to the public for free.
  • 2,071 Answers
It seems power supply section problem ,the voltage regulator transistor is busted already,and try to look also for loose,crack or cold solder,that is causes no voltage supply,you better to reworks the solder joint so voltages can supply....
Hope his may help you..
Regards,
VOTIT
    Sergeant:
    Champion:
  • 310 Answers
The problem in ur power supply circuit..
u can download service manual in this site
http://www.nodevice.com/manual/Panasonic/page28.html
    President:
  • 1,263 Answers
Ok if your getting power to it and you can turn it on and off but you don't get a display and you have no other controls, the power supply module on the main board is faulty. chances are from the heat that the unit receives over time has caused the fault. please rate this
    Genius:
  • 1,847 Answers
Do you get any error message ?
  • Legin Varghese
    Legin Varghese Sep 01, 2008
    like insert the the disk or disk not found or the disk is incompatible.
  • Legin Varghese
    the fist thing you should try different disks or a well worked disk in the past.
    if that is not working try cleaning the lens using the lens cleaner.
Powerware5115 will not switch on
A weak or dead battery pack its the main reason of a unresponsive/good health UPS, but never forget to test the electric cord, the fuse and the protective relay.first, this sounds too simple, but thats a common fault.
Battery pack must have at least 5 volts with half amp of current to power up the UPS internal relays, giving electric power to the main switch.
To rise the 12/24 DC volts to 115/120 AC volts, the UPS uses some electronic components (semiconductors) called MOSFETS , and sometimes, blown (browned) MOSFETS on the electric board are the most desastrous cause of a unresponsive (completely dead) or faulty UPS. (I remember that some time ago I see a TRIPP LITE SMART 1500LCD UPS with twelve blown MOSFETS, when happened, that kind of fault must be saw like a little volcano!).
If you know how to take all the safety electric measures, and how to use a portable voltmeter, you can test the voltage/amperage on the battery pack, the electric cord and the replaceable fuse (if has any). Basic and intermediate electronic knowledge is necessary to test MOSFETS and other electronic components on the circuit board.
Aug 09, 2014 | Powerware 9120 UPS System
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
Samsung notebook N150 Plus has gone completely dead
Try another AC outlet, try another cord/charger of the EXACT same power spec. Has the AC jack in the computer been damaged by pulling on the cord? Power surge? With a multimeter, verify DC volts at ac cord plug. Is the Laptop usually left plugged it when not in use? Do you shut it down and unplug when not in use?
Jan 20, 2013 | Samsung N150 Notebook
Laptop Acer Aspire 3354-1096 Power-up Problem
Do you have access to a multimeter to track the AC/DV current? If the power is getting to the laptop, correct DC/AMP voltage? AC jack been damaged, pulled, yanked...etc? Hard to say which component without checking with a multimeter? PSU?
Nov 25, 2012 | Computers & Internet
Power supply problem no switching
( "Power Supply Problem Not Switching "???? )
How do you know it's Not Switching? Do you mean the TV wont turn on when you push the power button on and off on the TV and also with the remote control unit? Is that what you mean? If YES! Then, If your Vizio TV wont turn on and has NO-PICTURE, NO-SOUND and a BLACK SCREEN, Then the TV has an AC or a DC Voltage Problem.
1 - First, check the wall outlet socket by pluging in a lamp to see if you have 110 AC-volts there. If the lamp works, the wall outlet is OK! That means the problem is inside the TV.
2 - Before, you remove the back off the TV. I want to *(CAUTION - YOU)* The Power Voltages inside your TV are Very, DANGEROUS!!! There is 110 AC Volts at a 20-AMP-Rating ***CAN BE A LETHEL DEADLY SHOCK HAZARD to HUMANS!!!*** Also there are DC Voltages ranging from 3.3 to 24 volts. And R-F- VERY-HIGH-VOLTAGE of 20,000 Volts or More.
3 - You will need hand tools and a Digitle Volt Ohm Meter to check AC & DC Voltages and the OHMS Meter section to check resistors, capacitors, coils, grounds and contacts.
4 - With the Back removed, and no-power to the set. Inspect the power board for any signs of BURNED, LOOSE or BROCKEN parts like resistors, capacitors, coils, fuses on all boards. If you discover damaged parts, make a list of them. Then you must deside if you are qualified to do the on board repair or just order a new replacment board.
5 - If on the other hand you didn't discover any damaged parts by your inspection, It's time to put the Meter to good use. Plug the TV power cord to the wall outlet. Set the Meter for AC - voltage range of 200 or more. check for 110 AC volts going to the power supply board fused inputs.
If NO replace the cord. If YES, look on the board for voltage test points marked on the board. (SAMPLE!) 3.3 vdc, 5 vdc, 12 vdc, 24 vdc, and so on. Set Meter for DC Volts now, range 50 to 100. Put the black lead to ground and the RED lead to each test point marked on the board while repetetedly pressing the TV power on & off button..
6 - If ANY of the DC voltages were LOW, WRONG or MISSING, The Main power board is defective and needs to be removed and replaced with a new one. Write down the board number that is on the board and use that number to order the new one. You can order it on the Net!
*****(NOTE)***** If you are not an electronics tech. don't try to fix the old defective board... but, keep it handy, you might need it for parts later. :-)
Hope This helped... GOOD LUCK! NOW, GO FIX YOUR TV!
Oct 08, 2012 | Vizio L32 32 in. LCD HDTV
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
My RCA TV just stopped working?
ok completly dead with no lights. this is indication of certain cuircit power loss. the main procesor is not receiving power. If i had it in my shop i would TRack the power. or backtrack the ac from the cord comes in through the courd and through the main fuse. then is converted to dc. 360 volts thats wherei would start. Now this is converted to 5, 3, and 7 volts. with regulators. which could be what was mention. I would recomend another tech. WARNING this set can hold that 360 volts even unpluged
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
