Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Blakc and Decker Lawn moser MM 875
When I plug it in, it blows a fuse.
  • 313 Answers
Unplug the extension cord for safety. then try turning the blade by your hand.if something is rubbing or hard to turn maybe the outring or out parts of the motor is broken.
Posted on Sep 05, 2008
What might causeI my electric mower to slow down and speed up and the electric cord connection has overheated at the mower connection?
there is approximately one OME of resistance per foot of power cord. the power cord must be sized according to the amps drawn. if the cord is undersized the motor will not get enough power. the results are a hot cord and probably a hot plug. a loos plug will also over heat, you may need to replace the outlet in the wall as well, get a 12 AWG cord if you are using a 100 foot cord. I personally would never use a 14 AWG if I had a choose, but if the cord was 25 feet or less that would probably be ok. if you are still using the old cord or if the wall outlet is damaged this could cause the ossolating current.
Jul 27, 2014 | Black and Decker USA MM-875 19" Mower...
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
Blakc & decker Ultra bread maker instructions has a copy of that manual.
Jan 13, 2013 | Black & Decker B2300 Bread Machine
Have b&s 800 series,new carb,head gasket set valve lash, starts but no increase in rpms
Blow back is probably valve lash with all the work u have done. Check also ur governor and make sure the spring is hooked up
Dec 05, 2012 | Briggs & Stratton 190cc 875 Series OHV...
875 Series Engine-cleaned flywheel and magnets and magneto. Put back together and now no spark to spark plug. What is the air gap between the magneto and flywheel.
You should put it at .020
Are you sure you had spark before you took it apart? If you are not sure, then the Ignition Coil may have went bad. How did it act before you decided to take it apart?
Aug 17, 2011 | Briggs & Stratton 190cc 875 Series OHV...
What is the spark plug gap for Brigg 875 series 190cc and how often should they be changed. Is a plattum plug any better
Set plug gap at 0.030 inches -- standard recommendation is to change plug every year. Few do that -- cleaning and re-gapping is what most do. Platinum plugs last longer...
Jan 05, 2011 | Briggs & Stratton 190cc 875 Series OHV...
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Mar 03, 2009 | Electric Lawn Mower
2 way switch,
see dewaltservcienet.look for search info.type in model #
Apr 05, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
244 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
