Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
F 11 KEEPS FLASHING
  • 9hankmud May 11, 2010
    Our Hotpoint Ultimate WT741 is flashing F11 - what does this mean ... is it something we can repair or do we need a hotpoint expert?
    Any replies would be greatly appreciated.
Hi i have a hotpoint condenser tumbledryer with the eroor code f11 coming up its a hotpoint ultima ctd85 can anyone help pls
Posted on Nov 12, 2009
F11 keeps flashing door won't open
Posted on Oct 08, 2008
F 2 keeps flashing
Engineer called to fix-poss pump
Posted on Sep 02, 2008
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
F-12 keeps flashing in the display screen, what does it mean?
if your machine is not taking in water and flashing this fault check your taps
Mar 29, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Dryers
My washer will not work at all just keeps flashing F1
You have a potential short circuit. Please ensure that you have unplugged at mains before attempting these checks!! Then you should make sure the wiring loom is secured properly to the motor. Check the wires around the motor to see if any have bared or are splayed revealing bare wires. otherwise the motor may be faulty.
Sep 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WF860
image_bubbleanswer_04.gif I recently had the same problem with my Hotpoint Ultima WF860P and after some investigations, I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Andrew Algar - Brighton
Feb 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
1,149 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
