Question about Maytag Neptune MAH5500B Front Load Washer
Neptune washer load noise.
During the spin cycle of the wash the washer make a extremely load noise like an jet taking off.
Does the drum have bearings in it?
Any suggestions?
  • Anonymous Sep 01, 2008
    It's a lemon. They're not suppose to make hardly any noise.
  • sbrunson1 Sep 11, 2008
    I have the same proplem. my maytag neptune front loader has started sounding like a jet engine while in the spin cycle. could a belt be loose?
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
Posted on Sep 13, 2008
Just had the repairman here today for a smoking problem with mine lately. He said it could be the "center bearing", so yes, there seem to be bearings in them. (He also said it could be the control board, so we are in a wait and see mode before tackling a $500 repair...)
Posted on Sep 01, 2008
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
Our neptune front-loader has become extremely loud during spin cycles, you almost need hearing protection, otherwise, it works great
Ball bearings have worn out. Replace as a set. Replace Water seals in the drum. Check the bearing shaft for any scrub marks. Check bearing housing. Fix new bearings now
Apr 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Noise hear during washing cycle?
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
384 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
