Question about Dell Axim X5 Pocket PC
Does the SD slot support IO devices such as Bluetooth or just SD memory cards?
    Master:
  • 852 Answers
NO SDIO. IO via CF only.
Posted on Sep 13, 2005
Micro sd card wont click into place garmin nuvi 2589
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Feb 28, 2016 | Garmin nuvi 2589LMT 5" GPS with Built-In...
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
Is thare a sim slot in dell axim 51v
Musaji Ahmed Hariff,
Your device has two slots located on the top of the unit. The larger slot supports CompactFlash Type II cards. The smaller slot supports Secure Digital (SD) memory cards, Secure Digital I/O (SDIO) cards, and the MultiMediaCard (MMC). All three memory card types are available in sizes from 64 MB to 1 GB or 2 GB. CompactFlash Cards Your device supports CompactFlash Type II cards. Some common types of cards include: • Modem - Connect a telephone line for modem data communication. • Wireless communication - Data communication without the use of cable connections. You can use cards, such as internal cards with Bluetooth wireless technology and 802.11b wireless LAN. • Storage - Save data or install programs on a storage card
You can click the link below to download the online manual for the Axim51v
http://dell.to/1WKDE1W
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 05, 2015 | Dell Axim X51v Pocket PC
I am trying to download pictures from my galaxy s fascinate phone and my computer is asking for a disc to be inserted to set it up. A disc did not come with the phone.
Most cell phones today have a few ways of getting pictures, music, videos to your PC/Laptop.
1. Via USB cable - This method usually requires drivers from a CD that came with your phone or can be downloaded from the manufacture's website in order for your PC to recognize your phone when you connect.
2. Via mini SD card - Most phones now have a mini SD slot where you can add more memory to the phone for pictures, music, videos, etc. Usually found attached on the side when you take the battery cover off. It will be a small black chip about the size of a finger nail and to remove it, you simply press it in, then it should release. If you have a memory card reader/slot on your PC/laptop, the mini SD card usually needs a separate adapter to make it fit into a standard SD slot.
3. Via Bluetooth - This requires your PC/Laptop to be able to connect with bluetooth devices. You must pair the PC with your phone first so they can communicate with each other. While using your phone, pick the file (picture, music, video, etc) from your phone, select Options, and send via bluetooth.
Oct 30, 2010 | Samsung Computers & Internet
How do i load music into my new i856 by boost
according to motorola, this phone has bluetooth and micro SD card slot.
if you have computer with bluetooth, then you can pair the computer and phone and simply send music files wirelessly via bluetooth.
if you dont have bluetooth, then you can buy a cheap usb bluetooth adapter from ebay and have a bluetooth enabled computer, then follow above step.
if you have SD card slot on your computer then you can get a SD card to micro SD card slot adapter from ebay or elsewhere, where you can simply put music on then card from pc and then transfer the card to the phone.
here is the phone manual.for safety read the whole manual.
p.55 for music and p.79 for bluetooth instructions.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i856/US-EN/_Documents/Static_Files/i856_UG__%20Boost_NNTN7815A_.pdf
Nov 06, 2009 | Motorola Mobility i850 Cellular Phone
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Sep 11, 2005 | Toshiba e400 Pocket PC
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Dell Axim X5 Pocket PC Logo
Clive
Clive
Alun Cox
