Question about Acer Aspire 3000 Notebook
When unplugged it goes directly to "critical battery"
Even after being plugged into the charger for hours it will not get a full charge. For some reason it will charge to like 7% or around that and not go above that and then when you want to unplug it to use it some where else it goes straight to "critical battery" and dies a couple minutes after using it while not being powered by AC power. Why does it do this? is there a way to fix it or is a problem with the computer??
    Brigadier General:
  • 5,158 Answers
Replace the battery.
Robert
Posted on Sep 08, 2008
Acer 4830 battery suddenly dead
Your battery is still alive, the problem is in the laptop, it may have a blown resistor or charging ic. I can bypass these parts tru jumpering if ever these parts are not available in the electronics store. Now, take the laptop in the computer repair shop nearest you for this is a hardware related problem.
Feb 01, 2014 | Acer Aspire Timelinex 4830t6443 Core I3...
Cobra cxt195 won't charge
There is nothing wrong with your battery or your radio. you bought it a walmart at the lowest price available. this means you get what you pay for i.e. no frills the indicator flashing means it is connected to a power source and is charging / Maintaining the battery. it will only come on again when the battery is below 1/8th of the battery life and flash to let you know it needs to be charged again. there is no battery level indicator. these will work just fine but dont expect the 1-16 mile range they advertize unless you have full charge alkaline batteries and a direct line of sight to the one you are talking to.
Dec 12, 2013 | Radio Communications
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
Why wont battery charge on laptop
A) The Battery is old, and beyond charging
B) The AC adapter (Charger) may be bad, and/or one of it's cables may be bad. If there is no one to test it with a multimeter, take it to a computer repair shop, and have it tested.
If bad suggest you look around at prices on the internet, before buying one from the repair shop. (If offered)
C) The port on the laptop, that the AC adapter (Charger) plugs into, is the DC Power Jack. (May be labeled as DC IN )
This jack may be soldered directly to the motherboard, in the laptop, or is attached to a cable which plugs into the motherboard.
For the style that is soldered directly to the motherboard, it's solder connections may have received damage.
Normal plugging in, and unplugging, may have cracked it's solder joints.
Bad connection caused by cracked solder joints, could = no power to battery. (Even though the laptop May be receiving power)
If laptop operates fine on the AC adapter, but the Battery will not charge, the problem may be a power sensor chipset, on the motherboard. May require replacement of the motherboard.
{ This chipset senses;
A) When the battery needs a Full charge, or just a trickle charge.
B) When the battery needs No charge, and power just goes to the laptop.
C) When the Battery needs a trickle charge, or full charge, and the laptop also needs power }
Regards,
joecoolvette
Jan 15, 2012 | Dell Computers & Internet
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
When I first switch on the new blackberry curve 8300 , the battery is not charging . The battery is not having voltage , around 0.7V. left it to charge for 24 hours , still the same. this is he first time...
there is some danger in charging a lithium battery once the cell voltage goes below a critical value .. so some chargers will refuse to charge such a battery .. you can "jump start" the battery if it hasnt been dead too long ... some special chargers do that ... they momontarilly force a voltage across the battery .. that gets the cell voltage above the critical value where the charger can kick in .. the charger will take over from there ... some people use a 9 volt battery connected momontarily across the lithium as a jump start .. but this is definatly not safe unless you know what you are doing ... if you reverse polarity or leave the battery connected too long then the lithium can overheat even explode .. once the battery is "jump started" then it should be monitored to make sure it doesnt get hot during charge .. if so you should replace the battery ... another possibility could be that your charger has a broken wire .. that usually happens right at the plug in connector ... if the charge light lights then thats not the problem ... if it doesnt or is intermittant as you wiggle the wire then thats a good place to start ..
Dec 23, 2009 | RIM BlackBerry Curve 8300 Smartphone
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Acer Aspire 3000 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
