Question about Panasonic PT-AX100U-EC DLP Projector
Projector shutting down after 2 mins.
I have a Panasonic PT-AX 100U projector that keeps shutting down after about 2 mins, even though I have not replaced the bulb and the projector shows a total usage of 195 hours. Can you help me?
  • 4 more comments
  • Anonymous Sep 29, 2008
    I have to turn the power off and then back on 3, and sometimes 4, times before the projector finally STAYS on.... it started doing this about 3 weeks ago... first just one reboot and now as I say 3, sometimes 4.
  • KDMyers56 Nov 08, 2008
    I have a Panasonic
    usage of ~300 hours. Can you help me?
  • Anonymous Nov 19, 2008
    I have the same exact problem with my LCD panasonic projector
  • krroller Nov 25, 2008
    I am experiencing this exact same problem. Is there a solution?
  • bmccarta Nov 30, 2008
    It turns off after 2 minutes and a red light comes on...
  • Anonymous Jan 19, 2009
    Same problem here too. Used to be able to just power cycle it once and it would work. Now it takes more.
  • 3 Answers
You need to send your projector to the Pasonic's repair center. The problem is the iris and should be replaced.
Posted on Nov 28, 2008
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Service manual for panasonic pt ax 200e
Goto scribd it is free to view online ;)
May 04, 2012 | Panasonic PT-AX200 LCD Projector
Turns on for 2 mins then shut down
It's over heating - open it and clean the dust out. Also, check the heat sink and make sure the heat compound has not dried up - remove the old dried compound and re-apply the new stuff.
Jan 29, 2011 | Panasonic PT-AE100 Multimedia Projector
My projector pt-lb10e cannot start up, the standby light is on but when try to press the on button nothing works. How can i reset the projector?
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
Sep 16, 2010 | Panasonic PT-LB10E Multimedia Projector
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
Projector keeps turning off every 5 mins
if just the lamp turns off and the rest of the projector is running, it's time to change the lamp. if the whole projector turns off (not goes through shut down), it may be a power supply problem.
Aug 19, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Ihave a panasonic projection model pt ax 100u
everything you need to know here... http://www2.panasonic.com/consumer-electronics/support/Televisions/Home-Theater-Projectors/model.PT-AX100U-EC
Jan 04, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AX100U-EC DLP Projector Logo
895 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
