Question about Kenwood Audio Players & Recorders
Kenwood kd42rb turntable do not turn! - Kenwood Audio Players & Recorders
Kenwood DP-R892
May be a broken belt. See if the turntable lifts out. There may be a circlip that holds it in or turn the player upside down taking care with the arm not to damage it. If the base comes off you may be able to see the belt. They are usually only the size of a skinny elastic band. If your turntable is a direct drive ( No belt) the motor may have failed.
Jun 27, 2014 | Kenwood Audio Players & Recorders
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
I need a kenwood P28 turntable belt drive.
If a belt cannot be obtained from Kenwood, a computer search for turntable belts will turn up several sources
Sep 24, 2012 | Audio Players & Recorders
Kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
Sep 11, 2009 | Kenwood KD-291RC Turntable
Trying to get the belt around the gears of my
I know this isn't the same model as yours, however it shows what I would describe to you on page 7. Hope this helps.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kd-491f.pdf
Jul 30, 2009 | Kenwood Audio Players & Recorders
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Turn table on hifi does not turn what is the problem
turntables are belt driven..... the belt could have snapped or come off.......
Jan 17, 2009 | Kenwood KD-291RC Turntable
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
Transferring Vinyl from Kenwood P26 Turntable to PC
Argos has a turntable for 90 pounds which converts Vinyl to MP3 or wave . There are similiar versions for cassette tapes. If you need help finding one. let me know
Mar 14, 2008 | Audio Players & Recorders
Kenwood Turn table
And play then at the same time.....those stopped being produced for the consumer market since the 90s. You will need to find a manufacterer still making automatic turntables..start from there, those those turntables usually are hard on records and offer poor fidelity.
Oct 03, 2007 | Kenwood KD-291RC Turntable
115 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
