Question about Dell Axim X5 Pocket PC
Can the sync cable be used for regular serial or usb connections to external devices such as GPS devices?
    Master:
  • 852 Answers
No the Axim does not support Serial Interfaces at all. It also doesn't have USB Host capability.
Posted on Sep 13, 2005
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
How to use drive and find serial number
HI. Connect power cable to unit and power source.
Connect USB to unit and connect to Computer. Turn on power.
Computer should auto matically load up unit and display on screen along with a menu and instruction for using.
Not to sure about serial number, would a have a close inspection in and around connections side of unit.
May 24, 2011 | Western Digital My Book Essential 1TB...
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
Drivers pc suit for lg kp110
i need pc suite for lg kp110
Dec 12, 2008 | LG CU500 Cellular Phone
Treo 650 wont sink
Assuming you are running Palm OS and not one of the rare beta Windows Mobile versions, here is my take on this.
Are you using a USB or Serial Sync cable? With either solution, make sure that the setting on the Palm Desktop Hotsync Manager is set to the correct setting (either USB, Serial, IR, etc). Conflicts between the cable type and the settings on your PC are common.
I prefer using USB cables since they are faster and you can tell if you are connected quicker than with a serial cable. Initiate the sync via your phone or the Palm Desktop Manager software. I have had faulty cable sync buttons and this was a good solution for me. If you haven't tried a new sync cable, you might want to.
Actually if you have time and a laptop, you can take your Treo to a Palm store and borrow one of their cables to try and sync. They were really helpful whenever I went in there.
Good luck.
Apr 26, 2008 | Palm Treo 650 Handheld
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
Tungensten E
If you are using the USB connection you'll need to check to make sure your HotSync is enabled for USB and not just serial port connection (the old default). Find the HotSync icon (red and blue arrows bent into a circle) in your computer's system tray (next to the clock) and right-click to bring up the menu. At the top you'll see "Local USB," "Local Serial," "Modem" and "Network." Make sure that there's a check next to Local USB. If not, just click on it, once, to enable it. Then, reconnect your Palm and activate the HotSync on the Palm (the star on the right side of the entry pad).
Let us know how it turns out, okay?
Nov 04, 2007 | LG KU990 Viewty
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
How do I sync my 3115 w/o USB??
Try infra red sync if your PC has an infra red serial port There is also this software..... http://www.bsquare.com/products/usbwin40/default.asp
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Dell Axim X5 Pocket PC Logo
112 people viewed this question
Clive
Clive
Alun Cox
