Question about Miele S514 Solaris Electro Plus Vacuum
No power The vacuum worked. Then cut off. I changed the bag and let it sit a bit. Then it turned on. I used it for about 5 minutes and now it's off again and won't turn back on. Is there a fuse or something I can reset?
  • clarkmeister Sep 06, 2008
    The suction is also turning off (though the brushes continue to turn. I suspect the motor is cutting off because of the fine dust that is a part of life in the desert. What I'm looking for is a solution. After 4 months of use, the HEPA filter is full and needs changing and I've gone through 3 bags though I probably only vacuumed the house thoroughly 5 times. Would using a non HEPA filter help? I also thought switching to a different bag might help, but only found the new Miele bags available in Europe.
Miele Capricorn whole unit shuts off totally off when I am using the Miele and I turn the powerhead sharply to the left. It an on-going problem that I have had serviced serval times. The last time the place I purchaced it from replaced the whole beadel bar which I paid over 300. for and the unit is 2.5 to 3 years old. I have to turn the unit back on at the cannister and the unit will turn on but it will cut off just like before when I use it and l turn the powerhead to the left.
Posted on Aug 12, 2011
    President:
  • 1,673 Answers
Does it shut off with the hose removed? If it does then there is a problem with the electronic control(mounted by the motor), or the motor itself. If it doesn't, then there is a clog in the hose, wand, or powerhead.
Posted on Sep 01, 2008
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
We have a Kenmore Progressive Model 116 Upright bagged vacuum with Hepa filter. It's at least a couple years old. For quite some time now when ever we use the vacuum the vacuum motor will shut off nafter...
I suspect that you have a restriction. The motor sounds like the thermal break is stopping the motor before damage, due to heat.
You must witness that the entire suction and discharge side are clear. This is not always very easy, but necessary. I bet that you find something blocking somewhere...
Nov 13, 2010 | Kenmore 34612 Bagged Upright Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
No power to my miele s558?
It's a bad model that's why they took it off the market. Mine is doing the same thing have taken it in twice for the same reason. First time they replaced the cord $200.00 which I did not believe it was the problem. A year and a half later still cutting off on me as if it's over heating I took it in and they found nothing. Took it home and it did it again within 5 minutes of using it, new bag inside suction was fine. Can't explain why this has happened since I have owned this vacuume. A LEMON! pilmammy@gmail.com
Jun 26, 2009 | Miele S558 Red Velvet Bagged Canister...
Lid won't close
You might have the vacuum bag in incorrectly. Pull your vacuum bag all the way out, and check the cardboard for arrows (as some bags are cut to go in one way, and one way only). If your vacuum has a cartridge that the vacuum bag goes into, make sure that this is seated completely, securely, and correctly. After you have checked all of this, seat your lid meaning make sure it is going to sit correctly on the housing, then as you are closing the lid, check the latch as it begins to close - making sure that the male and female portions are going to match up. You may have to give it a little pressure, but should not have to put enough pressure to break anything. Good luck.
Jan 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kirby Sentria doesn't pick up visible dirt
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Dec 08, 2008 | Kirby G6 Bagged Upright Vacuum
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Vacuumstps working
there is an overheat stat which cuts out motor if insufficient air flow. there must be a blockage you hav'nt found - probably in the air path from the brush roll to the fan
Apr 01, 2007 | Kenmore 33078 Bagged Upright Vacuum
Miele S514 Solaris Electro Plus Vacuum Logo
1,027 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
