Question about RCA L32W11 32 in. HD-Ready LCD Television
POWER WON'T COME ON
I HAVE A RCA L32WD12 THAT WON'T TURN ON. THE CORD THAT SUPPLY THE POWER IS WORKING. WHAT CAN I DO ?
  • 1 more comment
  • Anonymous Sep 18, 2008
    same problem here...how can we find a solution?
  • felipemtzol Jan 15, 2009
    Power on the outlet and connection cord working properly sending current to the TV but TV does not turn on. TV was being watched when it turned off by it self and have not been able to make it work.
  • jsssmrussell Jan 31, 2009
    Just watching the TV and it just goes off, use to come back on but now will not come on at all.
I have the same problem with RCA L32WD12
THIS TV IS ONLY A FEW MONTHS OLD HOW DO I GET SERVICE
JERRY
Posted on Sep 15, 2008
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Ineed a power supply unit for a rca l32wd12 tv were can i get one
You can order all parts for your TV set from Partstore here.
If they do not have the part in store, try Vance Baldwin : Encompass Parts Distribution.
Posted on Mar 01, 2009
  • 2326 Answers
SOURCE: RCA L32WD12 Power Supply
CN3 as follows:
Pin 1 >>> > 12 volts
Pin 2,3, 4 > GND
Pin 5, 6 >> 24 volts
Pin 7 >>>> ON/OFF
CN2 as follows:
Pin 1, 2 >>> GND
Pin 3, 4 >>> 5 VSB (Standby)
Posted on Dec 12, 2008
ginko
  • 19396 Answers
SOURCE: were can i get a power supply unit for a rca
You can order it from the link below:
274595
Do not forget to rate the solution.
Thanks.
Im looking for a power cord for an RCA L32WD12 32" HDTV flat screen..any help?
Hi Billy,
Unless the plug going into the TV is highly specific I would have thought that any standard power cord would do. Try radio shack or sears.
RadioShack
Sears Online In Store Shopping Appliances Clothing More
Aug 05, 2015 | RCA Televison & Video
No power
Great link Ekse.
Keep in mind that those parts are pulled from TV and their life expectancy might be short as well.
I've fixed hundress of power supplies with the same failures, about 80% failed due to defective capacitors the other 20% is due to other components in the power supply circuitry.
Aug 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
RCA L32WD12 will not turn on without several trys
Likely bad filter caps in the power supply---if you look inside and find this it may be a easy repair.
Dec 18, 2012 | RCA L32WD12 32 in. LCD HDTV
How to reset rca l32w012 tv
Hello
To reset your RCA TV, unplug the power cord from AC power socket, wait for 5 minutes. The set will reset to its factory settings. OK.
Oct 31, 2011 | RCA L32WD12 32 in. LCD HDTV
My tv was on when a power failure occurred(about 3hrs). the green light is flashing but the tv doesn't turn on. What can I do. Help
I HAVE THE SAME PROBLE WITH MY PHILIPS FLAT SCREEN. THEY TOLD US THE POWER SUPPLY IS OUT IN IT. SOMETIMES YOU CAN BUY THEM ON E-BAYCHEAPER THEN FROM THE MANUFACTURER. HOPE THIS HELPED
May 25, 2011 | RCA L32WD12 32 in. LCD HDTV
An RCA model L32WD12. will not turn on, what could be wrong
Hey folks: I found that the power supply in these rca L32wd12 to be full of open Capacitors as well as the relay card that has a SMPS circuit also to have bad caps. Replace all of these and this fixed the one I worked on. Remember all new caps are craps.
Jan 20, 2011 | RCA L32WD12 32 in. LCD HDTV
I have a RCA L32WD12 that suddenly turned off and on by itself. Now it will not turn on at all. The red power light is on, but the tv will not come on with remote or manually.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | RCA L32WD12 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Were can i get a power supply unit for a rca l32wd12 tv
274595
Thanks.
Mar 01, 2009 | RCA L32W11 32 in. HD-Ready LCD Television
Link
I was referring to the links posted by Ekse. If you could send me the info you have, I will point you where the capacitors are.
My email is jah2mil@hotmail.com
RCA L32W11 32 in. HD-Ready LCD Television Logo
846 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
