Question about Conair Compact Garment Steamer Iron
Replacement hose I need a replacement 5' insulated hose for my conair garment steamer. It leaks at the handle.. seems to be broken where the small screws are below the part where the wand can be removed. Any Ideas?
3 Suggested Answers
SOURCE: conair compact garment steamer
Push down and twist all the way- I had to watch it done on this website to figure it out!
http://www.handbooklive.com/index.php?nav=navprodsBySearch&search=gs4&prodid=13&title=Conair+Fabric+Steamer+GS4&xml=SteamerPlaylist
Posted on Oct 09, 2008
laura_b1215
  • 15 Answers
SOURCE: Re Conair garment steamer ctx12c
check out www.HandBookLive.com for a video manual under Appliances category (both GS4 and GS10 models have videos and show how to attach a hose in a Quick Start chapter- I am just not sure about the model you are asking about. It could be different
Posted on Nov 05, 2008
My GS23R fabric steamer does not work.
Time to return under warranty. There are no user serviceable parts.
Nov 06, 2014 | Conair GS33R Compact Fabric Garment...
Turning hose one quarter turn does not unlock. Therefore, cannot refill unit.
I've had my steamer for years, so not sure if the models have changed. However, it helps to know where the notches are.
  • Place the steamer with the red on-off switch closest you and the hose/refill cap facing forward.
  • The small notch is kind of between 7 and 8 o'clock (center of notch is about 1/2 inch to the right from the center of the black arrow marked above the "turn to release" on my steamer)
  • The big notch is kind of between 1 and 2 o'clock.
  • The notches on my hose are at the seams. Small notch is underneath the hose, large notch faces forward.
  • Line the front seam of the refill cap/hose between 1-2 o'clock. I pried with a flat head screw driver.
  • After I got mine off I marked the notches, but will still probably store it detached to avoid this in the future! Good luck!
Jun 09, 2010 | Conair Compact Garment Steamer Iron
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Sep 14, 2009 | Conair Compact Garment Steamer Iron
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair Compact Garment Steamer Iron Logo
213 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
