Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side serial # AF209778
Hi! I a defrosing the freezer part of my GE side by side because the ice maker has not worked since last December. I have turned the freezer off and I think that has stopped the air flow to the refrigrator part. Help, please!!
    Genius:
  • 1,847 Answers
Are the fan circulating air properly.
Posted on Sep 01, 2008
  • Legin Varghese
    Legin Varghese Sep 01, 2008
    You have to check physically that fan is circulating the air properly all the part of the fridge. just check by placing your hand against the vent.
    if yes the circulation is not proper then fan need replacement.
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
No ice being made
is the arm up for the ice maker to run? sometimes the arm gets bumped and shuts the ice maker off. some it needs to be up some it needs to be down.
Dec 31, 2011 | GE GSS22JFPCC / GSS22JFPWW Side by Side...
We have a GE side-by-side refrigerator. Ice maker has stopped making ice; however, the water dispenser still works.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 17, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ge profile arctica side by side- ice maker not working
heatman101
Aug 23, 2010 | GE Profile Arctica Stainless Steel Top...
Ice maker not working on GE side by side
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Hi. I have a GE GSS22WGMC side by side and for a
you might have 2 problems. First I think you have either a defrost problem or a evaperator fan problem.
Look at the lower back wall of the freezer and if you see frost build up then you have a defrost problem.
also open the freezer door and press the door switch button that makes the light go off and listen for the fan. if you don't here the fan its a good chance that it could be bad.
I would wait on the ice maker issue until the cooling issue is resolved because it could be causing the ice maker problem.
If you dont here the fan then ckeck it in 60 min again and if you still dont here the fan it is mostlikley bad.
If you do have the frost then one of the following compontents could be bad: Defrost heater, Defrost limiter or the Defost Timer.
Jan 10, 2010 | GE GSS22SGM Side by Side Refrigerator
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Make ice somtime but leaks or act like its defrosing
Hi: The ice maker is thermally protectec. In other words the freezer has to be at Zero degrees. Not just frozen, but zero. Your ice cream should be rock hard. Before you call a service tech try setting your freezer colder. Wait 24 hours before a change. It's human nature to check on the icemaker from time to time, But don't keep opening the freezer to see if it's working. You'll just dump the cold air out and make matters work. I hope this helps. Jeff
Jun 03, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
