Question about LG Microwave Ovens
Take microwave door apart completely on a lg 1935 sb microwave?
  • LG Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 02, 2008
New microwave got condensation between glass panels. Got new door happened again. I think it's a design defect. How can I disassemble to clean as needed?
To be honest-- it's not worth the effort. Some doors do come apart and some are glued together. If the replacement door is only listed as a complete door it doesn't come apart. If it does come apart, it requires prying the plastic frame off the inner side of the door to get to the screws. The frames usually crack if you are not careful. Contact Frigidaire customer relations and explain the problem and see what they have to offer either as a repair or explanation.
Apr 14, 2015 | Frigidaire Microwave Ovens
Magic Chef microwave oven
On alot of models the door comes as a complete assembly and can't be taken apart. Magic Chef is made by Maytag and I am pretty sure theirs do not come apart. If it does come apart then it is likely held togther by plastic tabs that have to be pried apart. The problem is they break easy and then you will be replacing parts. Guess you will have to decide if it is worth taking that chance because doors are expensive. I don't see your model # in the description but you can try looking a diagram by typing in your complete model # located on the sticker inside the microwave. Try sears.com and click on parts and various other repair sites. Hope this helps. Let me know if you have any other questions.
Oct 07, 2007 | Microwave Ovens
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
Door frame on microwave broke apart
If it is out of warranty, I'd just buy another. Most repairs would cost more than a replacement nowadays.
Nov 13, 2013 | Maytag MMV5208W Microwave Oven
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Door panel falling apart
Check repairclinic.com for parts on this unit. The door will run you about $121 item #1310935. If you just need the door frame assy. that's about $31 item#1300226. Good Luck.
Sep 25, 2009 | LG LMV1630ST Microwave Oven
Microwave Does Not Heat. Timer Works.......No Heat Display shows F-9 LG Microwave Oven/ Household Model LMVM 19455 SB Mfg. 2003
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 12, 2009 | LG LMVM1945 Microwave Oven
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Replace oven ligh on LG microwave
Hello Bob,
Here is a link to the service manual for your micro.. you should find everything you need to know about testing it and disassembling it as well.. Hope this helps you..
http://136.166.4.200/contents/Microwave/LMVM1945xx/LMVM1945_Service_Manual.pdf
Hope this helps you.. if it does, please rank this response accordingly..
Good Luck
Sep 30, 2008 | LG LMVM1945 Microwave Oven
Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Nov 19, 2007 | LG LMV1645 Microwave Oven
Microwave Ovens Logo
443 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
