Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba ice maker not dispensing ice
I have a KitchenAid superba architect side-by-side refrigerator and the ice dispenser stopped working. It makes ice but won't dispense. We just changed the filter and it stopped dispensing. We pulled out the ice bin, dumped out all the ice, melted everything inside, put it back in and it made more ice but still won't dispense. Any ideas what might be wrong?
  • 5 more comments
  • accocrash Sep 21, 2008
    I have the exact same problem. Water dispenser works fine. Makes ice fine just wont dispense.
  • Anonymous Oct 20, 2008
    we have the same problem with are KitchenAid supra, makes ice fine, does not dispense the ice. so we have to buy ice.
  • steveram Nov 02, 2008
    I have the same problem icemaker not despencing
  • f_wiggers Nov 08, 2008
    Will not make ice water or dispense water to drink. In past the filter needed to be changed, but the filer light says the filter is OK. This has happened before and opening and closing the door (seems) to have have it restart. Same with pushing all the button, etc. Now nothing seems to make the water system work.
  • RandySoCal Nov 08, 2008
    My ice make has been on the frits for about a year off and on.
    And now the ice maker quit totally. I noticed broken ice cubes in the
    tray so I removed and unpluged the maker and cleared the frozen broken
    ice pieces.
    I then replaced the maker plugged it back in and still have the same problem .
    I ice make don't even move . I checked my connection and there is power
    going to the unit. What am I missing . Please If you could help it
    would be great. I would be the family hero :-)
    sincerely, Randy
  • Anonymous Nov 08, 2008
    I have the same problem. I replaced the ice maker, it made one load, filled up, froze, but won't dispense. Does anyone have a solution? thanks
    H. Reiser
  • Canesdj Mar 23, 2009
    I am having the same problem, making ice but not dispensing, what I have noticed is that the ice bucket is not completely "clicking" in to place. An I believe this prevents the motor from working. Any ideas?
This is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
Posted on Mar 19, 2009
  • steve gandolfo May 12, 2013
    this happen to us and kithenaid fixed it on warranty, it was a design flaw, too short of a wire loom was used.
This might sound a little blond, but I was having the same problem until my daughter showed me that it was on lock...  just another little thing to check.. good luck..
Posted on Jun 11, 2009
The Line between the icemaker and the valve on the back has frozen. It happens about once a year on min. Remove the line on the back where it goes into the top of the freezer. Take a clean coathanger and warm it with a hair dryer. the run it thru the line. You may have to blow on it a couple of times as well but the ice will come out of the line and you will be making ice again.
Hope this helps
Mr Nascar, How can there be a piece missing if I'm the only owner and nothing has changed with my ice maker since I bought it 3 yrs ago?
Randy :-\
Posted on Nov 08, 2008
  • 57 Answers
Sometimes it could get hung. Therefore it will keep on and keep on making the ice. So you should turn off the ice maker and then take everything out and try to work with it.
Write me back and let me know :)
Posted on Nov 09, 2008
The problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
Ice maker makes ice but will not dispense it. water dispenser not working either.
check and make sure ur ice is not melted together. blockage can cause an issue
Jul 08, 2012 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working. water still dispenses but no ice is forming anymore. can you help?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghhdg
Feb 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
3,686 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
