Question about Epson Lx-1170 Ii Dot Matrix Printer
After turning on the EPSON LX-1170II printer , the Tear off + Paper out + Pause lights start all flashing... There is no sound or beep...I have no control on the printer's control panel ...I've restarted the printer many times , after long periods of inactivity , bat there's no change.... Please help me.
Riztech
  • 731 Answers
SOURCE: Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Posted on Feb 11, 2008
  • 61 Answers
SOURCE: pause & ready led blink alternatly after initilize
Check if the paper type is set correctly (in thebackside right there is a lever to set continuos paper, or single sheets).
Posted on May 03, 2008
SOURCE: Auto Tear off for Epson LX300+
epson 1150 printer on to printer all LED will be blicking
Posted on Jun 13, 2008
  • 83 Answers
SOURCE: configuration of page length
Most of these older printers use a special key to enter setup...usually upon power-up. Have paper inserted, because that is where it prints it's configuration.
It will probably use some of the feature buttons to change the paper size and tear-off options. Sorry I can't help with a manual, but I hope this helps.
B)
Posted on Apr 08, 2009
SOURCE: setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Posted on Jul 29, 2009
Why is my the printer making a beeping sound and why is the paper out/pauce light flashing everytime I want to print.
Because paper sensor is clogged and needs to be cleaned/replaced.
You may blow some air into paper entry from top of printer using pressurized air can.
Hope this helps.
Dec 01, 2010 | Epson Dot Matrix LX-300+ II Printer
How can i change font in epsonlx-300-II printer
Here is how:
1. Printer should be turned on, but not printing
2. Hold down PAUSE button for 3 seconds. The pause light will flash and the 2 tear off (FONT) lights shows the current font selected
3. Press Tear off(FONT) button to cycle thru fonts till light indicate the font you want. When you select the font needed it stays in use as default till you change it.
Note: Some software can change the printer font selected.
If need more information about your printer check the manual
Jul 31, 2010 | Epson LX-300+II Matrix Printer
What is error 16
There is an LCD Message and panel Light Status and a beep pattern which lights are flashing? Paper out? Pause? Tear Off/Set? Top Of Form/Set? Front? Rear? Turn off printer 4 five min then back on..what happens? error 16 means an unknown printer error.. with a dot matrix printer print head failure can cause different errors.
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Epson DFX-9000 Matrix Printer
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
Mar 13, 2009 | Epson LX-300 Matrix Printer
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Jul 16, 2008 | Epson LX-300 Matrix Printer
Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
Epson Lx-1170 Ii Dot Matrix Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
