Question about Sony PlayStation Portable (PSP) Console
PSP problem when you insert a game in the loading symbol shows but the game doesn't come on. What can I do?
Try and see whether "umd autostart' i set to on......dunno but that might help.....
Posted on Sep 01, 2008
Psp not reading games
Sounds like the laser is shot or the door is not making a good connection when its closed. So the system has no clue there is anything inserted. This could be from a bad latch, fried laser, or something on the motherboard itself. Does the spindle motor inside try to spin the disc?
Feb 24, 2014 | Sony PSP-3001
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
My psp when I open the psp theres nothing but sometimes when I open it without battery and put the charger and it shows up then i put the battery it works so sometimes I do not close the psp
Lets try that again...
I take it by "open up" you mean when you power on your psp yes?
by "there's nothing"do you mean blank screen? no power light? no loading?
From what i make of it your psp is not loading when the battery is inserted only, it will load when the battery is removed and the charger is plugged in only. After it has loaded you are able to insert the battery and remove the charger and you try to keep your psp running continuously so you don't need to take the battery out.
If I am correct in my interpretation you have a faulty battery that should be replaced.
Jun 01, 2010 | Sony PSP (Piano Black)
PSP Not Loading Games
You most likely need to clean the lens. Local game stores have kits that clean it for you.
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp will not load games
When you put the game in, there is a latch at the bottom the psp that when you put the game in, it tells the psp to load the game. When you put the game in, look and see if you see a silver latch that the game should push. If you see it, make sure the game is pushing down when inserted. If it is not there, or it still does not work, you will need to get it serviced at a game store or at a shop.
Jan 21, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP 3000 won't load games
u might wana check if theres any pieces mising in the back where u insert the gaame
Jan 13, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont notice any games
When you put the game in, there is a latch inside the back of the psp where you insert the game, at the bottom the psp, that when you put the game in, it tells the psp that a game has been inserted and to load the game. When you put the game in, look and see if you see a silver latch that the game should push. If you see it, make sure the game is pushing down on it when inserted. If it is not there, or it still does not work, you will need to get it serviced at a game store or at a psp shop.
Dec 27, 2008 | Sony PlayStation Portable (PSP) Console
Faulty psp
When you put the game in, there is a latch inside the back of the psp where you insert the game at the bottom the psp, that when you put the game in, it tells the psp that a game has been inserted and to load the game. When you put the game in, look and see if you see a silver latch that the game should push. If you see it, make sure the game is pushing down on it when inserted. If it is not there, or it still does not work, you will need to get it serviced at a game store or at a shop.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Console
Copy games frpm PC to PSP
ok u sould convert the game to PSP mode
there is a sowftare which will cos u only 456$ only :)
Nov 04, 2008 | Sony PlayStation Portable (PSP) Console
Psp not responding to umd's
I think u might b having a problem with ur umd drive .Changing ur drive lens can solve ur problem.
Jul 05, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
