Question about Brother FAX-525DT
Brother Fax 525 DT
I am looking for an ibnstruction book, "Brother" are not replying to me about this. In the first instance I need to attend to my ID and also check if I have put my correct telephone number into the system
Ring then direct 8.45 - 17.30 on 08444 999 444
good luck
Posted on Jan 28, 2009
When faxing documents on a Brother 525 fax machine do you put the item Face up or face down
If you have a Brother FAX-525DT, then place the document face down with the leading edge (top) down. The scan unit is on the bottom of the paper path for documents. The manual for the unit is available from Brother's EU division's support. The direct link is http://www.brother.com/pub/eur_fax_doc/fax515_525dt.pdf . The picture for how to position the document to be faxed is on page 55 (page 65 of the PDF).
I hope this helps.
Jan 27, 2016 | Brother Office Equipment & Supplies
Teeth are worn.
You'll need some feeler gauges, and other tools... I'll try to find a book for you that's quite ancient but gives you an idea of what you are looking at.
http://books.google.com/books?id=7iKdfV7-tOIC&pg=RA2-PA62&lpg=RA2-PA62&dq=Sewing+machine+cleaning+and+adjusting&source=bl&ots=grdcnme3vj&sig=_02oC2R04zlbVpuG0vvtdQhTam0&hl=en&sa=X&ei=JtpMUITLJIvrigKdkYGACw&ved=0CDgQ6AEwAA#v=onepage&q=Sewing%20machine%20cleaning%20and%20adjusting&f=false
Sep 09, 2012 | Brother Sewing Machines
I have a brother fax, model 525 DT. When you hit the number key for 7, it does not respond. In other words, that number does not appear in the window. As a result, the fax number is incomplete and fax...
Unfotunately you probably already know the solution here. The keypad needs to be replaced. There is a way to get into the pad and attempt to fix the individual key itself, but if you are here posting this, I'll simply assume that you don't have the technical skill required to fix that individual keypad.
If you purchased it recently, I would go to brother's website, find their support number and call them. It MAY still be under warranty. They can also advise you of any pricing and installation costs associated with replacing the keypad. I have over 20 years experience on office equipment, and I HIGHLY stand behind Brother and their services. Their support is very friendly and will help you... ;)
www.brother-usa.com
Sep 03, 2011 | Brother Office Equipment & Supplies
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
Paper size
I use Esselte Dataline 210x30x12.7, the code is 80428 and the last lot I bought cost me £2.99 but I am afraid it is quite a whilst since I purchase this thermal fax paper I cannot remember where I bought it from, but I hope this helps
Dec 12, 2008 | Brother FAX-525DT
Need to change my fax number on mfc-240 brother
i found out that i was looking for the wrong item it was under station id in the brother manual thankyou edward nielsen
Nov 22, 2008 | Brother Multi-Function Center MFC-240C...
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
http://www.retrevo.com/support/Brother-FAX-4100-Fax-Machines-manual/id/386bh847/t/2/
Jul 17, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother intellifax manual model 775
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Mar 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Resetting name and number on fax
The manual is on the Brother website. http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/ribbon/fax575_us.html?reg=us&c=us&lang=en&prod=fax575_us
Jul 20, 2007 | Brother FAX-575 Plain Paper Thermal
Brother FAX-525DT Logo
264 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
