Question about GE Zoneline AZ55H07D Air Conditioner
GE Zoneline az22e12d3bm1: Broken fan blade.
This unit quit cooling. I opened it up and found a broken fan blade. I am in the process of removing the blade but I cant get it off. Is there a trick to get the special nut off the blade (also called propeller)? Does anyone have a service manual on this unit? Thanks in advance...gwb
    Problem Solver:
  • 5 Answers
V O T E 4 O B A M A
Posted on Oct 29, 2008
Stat issues with GE Zoneline
Your coils on the outside unit may need cleaning.When they get dirty, air cannot flow through them to remove heat from the refrigerant. When this happens pressure increases until it trips a safety and shuts the unit down.
It won't run again until the pressure drops to a safe level. Also check your drain line..Make sure it's dripping.If not it's clogged and that will trip the safety switch not allowing water to back up
Sep 17, 2017 | GE Heating & Cooling
How do you take out the fan blade?
Because of the various different configurations and brands, its virtually impossible to tell you how to remove your particular fan blade. I will tell you that on these types of units and being so compact they are hard to work on. But I have included the care and maintenance of the unit. You might find this helpful.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-7559-1.pdf
The fan shouldn't be hard to replace once you slide the unit out of the framing. I wish I had more info for you. If I had some pictures of the unit, it would be easier. Good luck to you.
Apr 02, 2009 | GE Zoneline AZ28E12DAB Heat Cool Air...
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
HVAC
usually the compressor is broken. its inlet valve and the exhause valve sometimes are not as gastighten as before.
if that is true, your room cannot be cooled down.the compressor has to be replaced.
May 28, 2008 | GE Zoneline AZ55H09D Air Conditioner
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline AZ55H07D Air Conditioner Logo
291 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
