Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water is running into the ice maker
Water is running into ice maker and over flowing through the appliance!
and has now flooded my kitchen -- is there a valve that controls this ? Ive isolated the water supply untill i can find a solution,
Thank you
  • 943 Answers
Hi thanks for the question yes there is a water valve at the back where your water valve is replace the valve thanks the appliance doc
Posted on Sep 22, 2008
Whirlpool ice maker just making thin slabs of ice
What is the model number of your refrigerator this problem is usually caused by inefficient water supply to the ice maker on a whirlpool icemaker the fill valve seals for 7.5 seconds if the water flow is obstructed T-valve that are not recommended for refrigerator water supply lines the next problem could be your water control valve or the filters are clogged restricting water flow here's a short video
Appliance 911 Sea Breeze
Dec 04, 2015 | Whirlpool Refrigerators
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker water inlet keeps running
Replace the water inlet valve. It's on the back where the water supply hooks.You can turn the water off usually under the sink.
Dec 10, 2009 | Roper Refrigerators
Ice maker water keeps running
Please keep in mind that I am attempting to diagnose a problem with your appliance without being there and with very little information.
My first guess is you will need to replace the water valve. How fast is the water coming out. If it's a trickle, you have a bad water valve. If it is flowing as hard as it flows when the ice maker calls for water,
there could be a problem with the switch inside you ice maker is bad and continues send a signal to the valve to keep sending water. You can check this by unplugging the ice maker from inside the freezer and if the water valve stops sending water. You will need to replace the part inside the ice maker or replace the whole ice maker.
Please rate solution
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water Flow out of freezer compartment
take wires off inlet valve if it stops replace ice maker
Aug 31, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Whirlpool refrigerator side by side
hi. thanks for the question. To see if the problem is with the water valve, or ice maker. remove 1 wire from water valve ,at the back . now turn on the water . if water still flows. replace the water valve . if not replace the wire and try again .if flows replace ice maker. thanks the appliance doc
Sep 30, 2008 | Whirlpool ED2FHEXN Side by Side...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
