Question about Packard Bell DR724 Motherboard
Soundcard problem I recently formatted and re installed WinXP and lost all access to my audio files. Error read No audio device found.
  • rajaazhar Sep 03, 2008
  • 781 Answers
If it is on board sound you probably need the M/soft UAA drivers
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
Go to the above site and download and install them
then go to device driver right click sound and upgrade them it will go on net to find and install them
Posted on Sep 01, 2008
My computer does not recognize the sound card anymore.
Usually happens when Windows is reinstalled, such as using a Restoration/Recovery disk.
Sometimes Windows just has a brain f@rt.
Looses the address to the Driver file
(All the files on the Harddrive have an Address.
Losing the address could be equated, to loosing an address to someone's house, or a place of business.
Don't know the address of the house, or business, you won't find them)
Suggestion is to download AND install, the driver file for the Soundcard
Driver: Small piece of software that allows the Operating System to communicate with a device
The device is the audio chipset.
Do not know which version of Windows is being used, for the Operating System
Soundcard
A heavily misused term
Misused if meaning Integrated Audio.
Audio (Sound) chipset is mounted (Soldered) directly to the motherboard, and is NO soundcard.
A Soundcard is a sound adapter card, that is plugged into the motherboard.
IF it is truly a soundcard, I need the manufacturer's name, and model number of the soundcard. The model number will be on it.
If it is Integrated Audio we will go on...........
[The I/O area of the computer is on the Back of the desktop computer.
The I/O area is part of the motherboard.
I/O stands for Input/Output.
So this means the I/O area, is the area on the motherboard, where Input devices are plugged in, and Output devices are plugged in.
Some common Input devices are the Mouse, and Keyboard.
Some common Output devices are the Monitor, and Speakers.
Speakers. SOUND.
If the audio cables are plugged into an audio port in the I/O area, you are using Integrated Audio.
I/O area. Rectangular area, that also has the sheet metal, I/O Shield surrounding it.
The Horizontal slots on the back of the computer, (In the metal framework), are Expansion Slots.
The back end of an expansion adapter card are seen in these slots, IF one is installed.
A Soundcard is a type of expansion adapter card.
It's a sound adapter card.
Soundcard
IF you truly have a Soundcard, it will be in one of these Horizontal slots ]
ECS Support > ECS P965T-A > Main support page,
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=666
Scroll down a little, click on the white subheading - Sound
Driver name - Realtek High Definition Audio Driver
Version 2.40 (5700)
Go to the bottom of the 'chart', and to the right of - Download,
click on the country NAME nearest yours.
A small window will come up -
Opening 3_Realtek_1021.zip
Make SURE there is a Green dot in the small circle, to the left of -
Save File
IF not; left-click on the small empty circle, to the left of - Save File.
Now go below in the window, and click on OK
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on it.
If a Microsoft 'Squawk Box' comes up, click on OK.
Security warning comes up after that, click on Run.
(It's from ECS. Elitegroup Computer Systems.
It IS OK)
In the next small window, go to the far left side, click on -
Extract all files
At the bottom of the next 3 small windows click on -
Next, Next, and Finish.
If you are Not asked to restart your computer, do so.
(WinXP: Click on Start > Turn Off Computer > Restart)
No Volume icon in your system tray?
(Tray at bottom of desktop screen. Look to the right. The Volume icon is a Speaker symbol)
Using WinXP for an example;
Click on Start > Control Panel > Sounds, Speech, and Audio Devices
At the bottom right click on Sounds and Audio Devices
Under the blue subheading - Device volume - make sure there is a Green checkmark, in the small square to the left of -
Place volume icon in the taskbar. (Taskbar = System tray)
IF not; left-click in the small empty square, to the left of -
Now go below to the Right, and click on - Apply
Then go below to the Left, and click on OK
For ANY additional questions please post in a Comment.
I can explain in more detail, or more simply, if needed.
There is NO such thing as a stup-id question. It's just a question that hasn't been asked yet.
Regards,
joecoolvette
Feb 05, 2013 | ECS P965T-A Rev 1.0B Socket 775 DDR2...
My toshiba has no sound
there is some system files are missing .
Go to start menu then type in run "cmd"
then ou see command prompt.type there "sfc /scannow"
then it scan for corrrupt system files when it need winxp source put the winxp disk in cd-rom then it get files.
Jul 15, 2009 | Toshiba Satellite A75-S213 Notebook
ASUS P5KPL-AM VIA HD Audio Device not found
I would try the realtek audio driver instead. there are two different audio drivers for that board. Here is the link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
select the socket 775 then look for the p5kpl board then look in the audio section and select the realtek driver
Jul 15, 2009 | Computers & Internet
I hear no sound in my pc
Are you using the same operating system? It seems the driver is incompatible with the operating system you are using. Try downloading the latest driver from the Intel support website.
One other option is to check if your onboard audio device is enabled in the BIOS. If it is not, the device won't be detected of course.
Jun 09, 2009 | Computers & Internet
I just formatted my computer and now i cant play a music file
You will need to reinstall the driver software for your soundcard. Go to the website for your computer manufacturer and search for your model computer and download and install the audio drivers.
Example sites:
support.dell.com
support.hp.com
May 26, 2009 | Computers & Internet
My soundcard is not working
there is a driver for sound card which should be installed,ur comp engineer normally has it ready with him, once the souncard driver is installed all ur audio's will work..
May 15, 2009 | Intel Creative Labs Sound Blaster 16 PCI...
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Audio driver site
http://www.soundcard-drivers.com/drivers/137/137234.htm
Dec 26, 2008 | Car Audio & Video
Problems with my sound card
Try to install sound card drivers from http://www.soundcard-drivers.com
Gizmo1
Oct 13, 2007 | LG X-Note LM50 Notebook
Packard Bell DR724 Motherboard Logo
319 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
