Question about Toshiba e750 Pocket PC
Touch screen unresponsive
I did a hard reset on the pda, and now I can only get to the "tap screen to set up", but it will not respond to the tap. Any suggestions?
  • Helpmendit Mar 31, 2009
    I have exact same problem... Does anyone have a resolution?
  • rudybs Apr 29, 2009
    i dont know,suddenly my e750 cant open anymore,after i setting manual wifi
I'M NOT SURE IF THIS IS MY REQUEST,BUT THIS IS THE SPECIFIC PROBLEM. I THOUGHT THAT REINSTALLING THE OS AND DRIVERS MIGHT GET THINGS STRAIGHT, ALSO I WOULD LIKE TO UPDATE THE OS, SINCE CURRENTLY I DO NOT HAVE ANY DATA OR EXTRA APPS THAT I AM WORRIED ABOUT LOSING DURING AN UPGRADE. WHAT DO YOU THINK? I DON'T KNOW IF AN OS UPDATE IS AVAILABLE , OR IF THIS WOULD BE POSSILE.
Posted on Feb 03, 2010
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
Aug 14, 2012 | Samsung Lands Phones
Touch screen not working I have reset but screen not working
u have to go any repairing shop n show it then they will set its chip which is internaly connected with ur palm
May 10, 2010 | Palm Zire 31 Handheld
I can not sync
HI,
The first thing you need to do is to reinstall the palm desktop software to make sure you have the most up to date version. After you do that try doing a hard reset. You want to make sure you have everything backed up from your PDA to your desktop because when you do the hard reset it is going to erase everything on the PDA and restore to just like it was brand new. You will have to reset the time and city and calibrate the screen by tapping the little targets.
To do the hard reset follow these instructions:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus2.gif.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen2.gif and go through the tapping the target. After you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
Oct 14, 2009 | Palm Z22 Handheld
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
Slow respond
The best solution to these problems is hard resetting your device. A hard reset will bring your PDA to it's factory default state, so your PDA will be as fast as it was when it was brand new. But this process will erase all your stored data (Such as adress book, messaged, appointments, tasks, pictures, ...) so you should consider having a backup of your PDA to your PC with a backup software before you hard reset your device. So later when you hard reset, you can recover the personal data with this backup file and continue using your PDA faster.
To hard reset your PDA, you must press the on/off button and reset button at the same time (reset button is a small button that needs to be pressed with your pen, and usually it is located in the bottom of the PDA). And later, wait a couple of minutes and the windows will be reinstalled and load up with the starting page of the screen alignment. After you completed all the settings, you can recover your data from your backup file (from PC).
Apr 03, 2009 | O2 Xda IIs Pocket PC
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 05, 2009 | HTC Touch P3450 Smartphone
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
IPaq rx3115 screen unresponsive
Bad screen if the driver was bad they would tell you that you are having a problem with the driver
Feb 07, 2009 | HP iPAQ RX3115 Pocket PC
HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
Aug 28, 2008 | HTC Touch P3450 Smartphone
Toshiba e750 Pocket PC Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
