Question about GE GSS20IEP Side by Side Refrigerator
Changing filter Our water has things floating around in it. How do you clean or change the filter. I can't find the manual on the ref.
    Novelist:
  • 166 Answers
Peace,
ngafm at your service ,
here you can find and down load your manual from ge!
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=GSS20IEPWH
Bless You,
Please give me the best rating before you sign off1
Posted on Sep 09, 2008
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
I put a new filter in my Sansung Refrigerator and the water taste worse than the old one, why?
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
Jan 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
Oil leak at filter
If it's at the filter replace the filter. If it's at the mount/engine side replace the seal/gasket. The filter bracket is taken off by removing the filter. The screw that the filter goes on has a nut built on it. remove it to remove the bracket. If it is a seal get a new one and add some silicone. If it is a gasket, clean it off, just use silicone.
Apr 07, 2014 | 1999 Chevrolet Silverado 1500
Transmission filter and fluids were changed but the truck hesitates in drive .when i shift to low 1st gear the vehicle pulls off fine. this didnt happen until we changed the filter kit an added new...
Sorry to say it probably won't get any better.
Most mechanics will not recommend changing the fluid and filter if the transmission has more than 125,000 miles on it unless it has been changed every 50,000 or so.
Once you disturb the fluid and what is floating around in the pan, things can go wrong.
It could be a clutch, band, the valve body, or the pump.
Feb 09, 2013 | 1994 Isuzu Trooper
I have a side-by-side ref. It use external filter. I notice that water out of filter (before going into ref) is clear but when I collect water from water dispenser of my ref is cloudy and some very tiny...
was the outside filter factory? by this I mean does the unit have an internal filter ? if no, then you need to flush the system, clean the outside dispenser components, lime or rust has accumulated on the dispenser if the water from the outgoing side of the filter is clear ( is the ice clear and fed by this same water source? if so,, its just outside build up that needs to be cleaned
Jul 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We changed the filter to the water dispenser but
run about 2 gallons of water through the filter, if it did not help - the stuff is coming out the tubing between the filter and the dispenser. Check water hardness. If you have water softener, make sure it works properly.
Apr 11, 2010 | Whirlpool ED2FHGX Side by Side...
How do I change the water filter?
changing the water filter is a easy job on most ref . how ever there different models / so i will look yours up / i wil get back with you in just a min . _______ I back the part # 4396508 is located down by your toes. in the grill . .remove the grill and 1/2 turn and pull out . change the filter . you don't have to remove grill but those thad do will be able to clean the coil. ( very important . good luck hope this helped **** ..
Jan 06, 2010 | Whirlpool GS5SHAXN Side by Side...
I have a 150 black max mercury outside the water start and ref fine but inside the dam when you want to pull away it stals and goes dead i think is a petrol problem i give up please help me.
Try changing the fuel filters. The ethanol has probably been cleaning out the gunk in your tanks and plugged the filters. If you have in line filters change those and check the owners manual for any filters or screens on the engine itself.
Sep 18, 2009 | Boating
Water Filter leaking after changing filter
There's probably some particles that got trapped in the filter purge valve ( the red button) preventing it from closing all the way.
You may be able to clean the valve while the filter top is still in place. Try using a small brush. A toothbrush may work if you cut off the handle. Hold the button down while you clean the inside of the valve. Then take a
spray bottle and put the sprayer tip on stream. Flush the valve from the inside.
If that did not do it, next step is to remove the top from the water lines, and flush the valve out.
Jul 19, 2009 | Culligan Under Sink Water Filter
No water nor ice comes out
do you have water pressure to ref. water control valve? check voltage to water control valve assy. note: very difficult to diagnose these control valves, replace them both and be done with it.
Apr 23, 2008 | Maytag MZD2766GES Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
