The D-Link wireless router doesn't give a strong signal to computers farther away in the house. What should we try?
    President:
  • 2,961 Answers
All you can do is buy a signal booster /extender or put the wireless router in a higher or more central position.
Posted on Sep 01, 2008
Inconsistant wireless signal in house
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Jan 18, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I have a 655 router.. running windows7 on one computer on Home Network.. Router initially working OK..computer connected via cat5 wire. Disconnected router, moved to new location on desk...reconnected...
You can reset both the modem and the router by removing the power cord where it connects into the router (Called Recycling the Power) I would do it with both the modem and the router for about a full 2 minutes.
Sounds more like you have a connectivity issue from interference from something on you desk. Some known culprits are:
High Intensity Lamps Fans Radio Interference coming from your wireless phone Power strip with filters for telephone signal any other environmental issues including computer monitor. Next door neighbor's router signal bleeding through. Filter device missing from phone Filter device missing from phone line connected to you TV
Try moving the router back to the old location. Does problem go away. You are now too close to something thats breaking your signal. I can log into my neighbors access point across the street and two houses away. Signals are strong but can be blocked by a lot of things mentioned above or tin foil.
Check it out,
TF
Jun 03, 2011 | D-Link DIR-655 Wireless Router
I have a DIR 615 Dlink wireless router connected to a Dell computer running XP Pro. Checked for latest firmware, had it. About every 2 or 3 days it will stop broadcasting a signal and I can not logon with...
Ok this might be a bit tricky but it sounds like there is another wireless signal that may be interfering with yours.
Do you have an older cordless phone in the house? If so try and move the cordless base farther away from the wireless router. Even if they are on different floors in your house, if they are located near each other the cordless can interfere with the wireless signal.
The other possibility is that there is signal that is coming from the outside of your location and is causing the interference.
I know that when I had an XP Pro machine (Laptop) it would drop the wireless signal every couple of days or so. I traced my problem to my neighbors cordless phone. he had an old one and it was near the side of my house that my router was on and it was causing me problems so I move my router and the problem went away.
hope this helps
May 21, 2011 | D-Link DIR-615 Wireless Router
Wanted to replace the antenna with an 18db but the original looks like it is not removable. if i used my wireless G instead woulkd I get a stronger signal
Simply put, no. Wireless B is more reliable at longer distances. Wireless G gets slower the farther away from the router you are, to the point where the signal is unusable.
Mar 24, 2011 | D-Link Wireless N 150 Home Router 4Port...
If my pc has a strong internet signal - why can't I go online?
its a wireless signal may have to move it around to get your signal things such as walls ,appliances distance can cause signal loss
May 18, 2017 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless router signal
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
Aug 14, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
