Question about Yamaha HTR-5230 Receiver
Yamaha htr5230 hookup
How do I hook up my yamaha htr5230 to my television. I have the receiver along with the 5 speakers including the sub woofer but I can not hook it up to my tv along with my dvd player, help? I do not have the manual or the remote controller.
    Problem Solver:
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
Posted on Feb 27, 2009
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Yamaha HTR-5230 Receiver Logo
286 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
